on 24-04-2022 03:11 PM
I requested, and received, a new router, as my old one frequently dropped connection to my security cameras. Since installing it, the situation is worse not better. Not only are device drops more frequent, requiring router resets, if our phones and tablets have picked up one of our extenders, as we move through the house, they usually will give an "internet may be unavailable" when they pick up the router again ( even though they can still get internet if switched to an extender, then back to the router). I'm beginning to think there may be a DCHP issue with the router. Any advice?
on 07-06-2022 07:12 AM
I'm sorry to hear this. Can I just confirm, is it the wireless which is dropping or wired devices too? Do any of the lights change on the router when this happens?
on 06-06-2022 03:41 PM
We're still having Drop-off issues. Things seemed stable for about 2 weeks, then the problem started to reappear. Any suggestions?
on 30-05-2022 06:14 AM
Glad this has helped.
on 27-05-2022 04:02 PM
Turning off optimisation seems to have helped. Things seem much more stable now.
on 17-05-2022 06:59 AM
I've turned off wifi optimisation for your router, see if this improvers the connectivity / performance for the devices.
on 16-05-2022 08:47 PM
This is an ongoing, and very frustrating, problem. There are 2 types of issue,
1. Our 2 security cameras ( 2.4GHz) frequently get disconnected. There is no obvious pattern, it just seems random. Sometimes they will reconnect, other times a router restart is required. Both cameras, being at some distance from the router, are served by extenders. I have changed the broadcast channel from 1 to 6, but this has made no significant difference.
2. Our phones/tablets frequently get the "Internet may not be available" message. We have to disconnect from the router SSID and go onto either of the repeaters, then go back to the router to regain internet access. It's as if the router loses track of the IP addresses it has allocated.
Help needed!!!!!
on 16-05-2022 07:52 AM
Thanks for your PM. Are you able to reply to this topic please?
on 25-04-2022 09:18 AM
Hi Scotslider
I can see that you are using a Sagemcom WIFI hub with latest FW version 136.
Is this only affecting the wireless connection or are wired devices also affected?
24-04-2022 06:54 PM - edited 24-04-2022 06:55 PM
Hi @Scotslider,
What model of router are you now using ?
The TalkTalk Support Team on this community may be able to offer more help, they will hopefully be able to respond to this post tomorrow.
