Router firmware for ex-TT customer
Cheese_za
Message 5 of 5
Is it possible to get router firmware if I'm an ex-TT customer?
I moved away from TT because I moved house and openreach speeds in the new area were pathetic at the time (think they still are).
Need to expand wifi want to use my 2 TT routers are WiFi APs/bridges and just want the the latest firmware if possible.
I have an HG633 and HG635.
4 REPLIES 4
Message 1 of 5
If your just using the said router as wifi extender you will be having DHCP switched off I guess. So i bet any update might not even be needed as all main signal etc is coming from Gateway/modem/router
Message 2 of 5
Without breaching lockdown rules, obviously.  🙄
FritzCT
Wise Owl
Message 3 of 5
If you don't currently have the latest firmware then it's time to speak to family, friends, neighbours, etc. to see if any of them are with TT and willing to connect your kit for it to update.
Don't be tempted to download the firmware from 3rd party sites as you've no way of checking its origin.
Fritz
Message 4 of 5
The routers need to communicate with TalkTalk servers and they cannot do this unless you are on a TalkTalk line. What versions of software do they have currently? They may well be up to date already.
