Router has wifi disabled and I can't reenable it
JasonF
Visitor
Message 12 of 12
We got back from holiday and our wifi had stopped working. Our connection is fine, I've done a load of line tests and it works via a wired connection. When I log into the router it shows the wifi as disabled, despite the fact that the switches are enabled. Please can you help? I've attached screenshots to help show the issue.
Thanks,
Jason
11 REPLIES 11
Message 1 of 12
Message 2 of 12
Thanks Chris - hopefully this will sort the issue.
Message 3 of 12
Hi jasonF,
I've ordered the router, it should be with you within a couple of days but please allow up to 5 working days for delivery
Message 4 of 12
Yes please, that would be great thanks.
Message 5 of 12
OK thanks, would you like us to send another router to test with?
Message 6 of 12
Hi Chris, I've already tried this a few times. I've done it again anyway, and it hasn't resolved the issue unfortunately.
Message 7 of 12
OK thanks, yes I can see that you have an Internet connection now. Could you please try resetting your router to factory default settings - Restore your router to factory settings
Message 8 of 12
We had a lightning strike on a telephone pole near us last night, the Internet wasn't working this morning, but it seems to be back up now.
Message 9 of 12
Thanks for updating your profile.Your router doesn't appear to be connected to the Internet at the moment so could you switch your router off and leave it off for at least 30 minutes then switch back on and retest - please let me know how you get on
Message 10 of 12
Thanks Chris, I've updated that information.
Chris-TalkTalk
Message 11 of 12
Hi JasonF,
  • Name
  • Telephone number
  • Alternative contact number
