Router login details
zofbtb
Message 5 of 5
Having a play with my new router and see the latest firmware adds "reserve IP" which is great. The only thing I can't find is the username and password - the Phonenumber@talktalk.net bit
4 REPLIES 4
zofbtb
Message 1 of 5
Message 2 of 5
If you change from DHCP to PPP the setting will become available, but you should not do that if you are on a TalkTalk line.
zofbtb
Message 3 of 5
But TT's routers can be used with other ISPs (ie you can buy them) so thought somewhere in the GUI there'd be the 2 fields
Message 4 of 5
There isn't one, TalkTalk use remote authentication.
