on 11-05-2021 09:10 PM
New to talktalk having come from BT.
With BT we had a reliable 40mbps download throughout the day.
Since starting with talktalk it has been terrible. After a router reset we get around 32mbps, and that steadily drops throughout the day and by the evening down to single figures. At this point iplayer etc won't work and we have to reset router again.
We are not heavy users, just 3 phones, one smart TV and a work laptop and ring doorbell.
Any ideas to fix? Or do i just need to go elsewhere as this just isn't going to work longterm.
on 24-05-2021 11:08 AM
I'm sorry to hear this. I've re-run the line test now which is clear and the sync speed looks consistent. Just to confirm, is it still only of an evening when this happens and does this also happen if you connect wired? Please can you run a few more wired speed tests using the TalkTalk Speed Tester when the speeds are good and also when the speeds drop and we can pass this over to our Network Team for further investigation.
on 22-05-2021 11:42 PM
New router received and no better.
I am sure it isn't congested wifi from neighbours etc as we live in a detached house with a good distance from our neighbours and nothing has changed from our BT set up. We literally unplugged the BT router and plugged in the talktalk router and our problems have started.
Unless I can have a guarantee that it will be fixed then I will want to invoke the 30day connection guarantee and move to another provider with a better router (I assume router issue as getting 39mbps to the router).
on 17-05-2021 09:04 AM
Hi paul080803
I've ordered a replacement router for testing, please allow 24-48hrs for this to arrive.
on 16-05-2021 10:17 PM
Done, thank you.
Thank you for the reply!
Did a connection test and no fault.
Landline phone is working fine.
No test socket in the house. We are using the same socket as the BT hub was connected to so we know the house circuit is fine.
I went into the router admin and it stated 38mbps connection speed. I suspect it is the router that is faulty on the WiFi side. I have updated profile so hopefully they will be in touch.
on 12-05-2021 08:36 AM
Hi paul,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 11-05-2021 10:01 PM
Hi @paul080803,
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
If the staff here thought this might be an issue with the router itself they would be able to arrange a replacement for you.
