Router not Wi-Fi discoverable
Jmchattie11
Message 2 of 2
Having had the engineer install our router and establish a solid white light the router itself has not been discoverable for any device wirelessly. The internet connection itself is fine as Ethernet connection works. I have tried resetting the box, turning it off and on and changing the settings but it is stuck with the wi-fi setting being set to disabled, even when I change this to enabled the status remains disabled??
1 REPLY 1
Message 1 of 2
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
