Router not showing system logs - requesting a replacement
SilverFir
Message 4 of 4
I've been trying to access the system logs on my router but there appears to be none, it's just blank, no information in the section. I looked online to see if others have had this problem and found that its some kind of fault with the router so I'm looking for the unit to be replaced.
System Information:
Router - Huawei-HG633
Device ID: 00E0FC-C4REQ16428005508
Hardware version: H.1.01
Software version: v2.00t
Regards Adrian
3 REPLIES 3
Message 1 of 4
Hi SilverFir
Please let us know how the connection compares with this router.
Message 2 of 4
Awesome, thanks for the help.
Adrian.
Message 3 of 4
A new router is on the way to you.
This should arrive in the next 24-48 working hours.
