Router not working
Jude M
Message 5 of 5
My faster fibre router isn't working suspect it is a power issue, but can't be sure would appreciate finding out how to go about fixing it/replacing it
4 REPLIES 4
Message 1 of 5
Hi Jude
Apologies for this.
Message 2 of 5
Hi I've tried to reset it but no lights come on
Message 3 of 5
Hi Jude
Are there any lights showing on the router?
Have you tried factory resetting the router using the pin hole reset for ten seconds? If you have tested this and are still experiencing this issue then I will send a replacement router.
Skynet_TX
Message 4 of 5
Hi @Jude M ,
The staff on this community will back back tomorrow and should be able to respond to this post within a day or two. If your router has died they will be able to send you a replacement router together with all the cables.
You may get faster support from the live chat or by phoning up during opening hours.
