03-08-2020 06:50 AM - edited 03-08-2020 08:49 AM
My sagecom fast router kept rebooting every other night, dropped my profile by DLM. It is now on solid orange and have totally disconnected it so I'm totally offline.
May I please ask for a replacement router same model Sagecom fast?
on 18-08-2020 12:35 PM
UPnP should now be off.
on 17-08-2020 04:43 AM
Good morning,
Due to safety concerns may I please ask for Upnp to be turned off. I've always kept it off in the past with my previous ISP. It's only now I realised it's on by default and I can't turn it off by myself.
Thanks,
kannanni
06-08-2020 07:53 AM - edited 06-08-2020 07:54 AM
HI kannanni14
The line tests are all clear but I would advise keeping the router connected at the master/test socket for 48hrs, without rebooting whilst DLM is monitoring the connection.
The WiFi Optimisation has been switched off.
06-08-2020 07:35 AM - edited 06-08-2020 07:48 AM
Hi there,
Replacement router came yesterday and plugged in.
Can you please run a check and see if it's a healthy connection.
And also turn off WiFi optimization, it was off on the other router and I'm not sure if its still off.
I had problems with my main pc dropping connection and you guys turned it off for me last time.
Is there a chance you can also send me the latest black Huawei WiFi hub so I can test and keep what's best for my line please?
Many thanks
on 05-08-2020 11:47 AM
HI kannanni14
Thanks for your reply. Please let us know how the connection compares with the replacement router.
on 04-08-2020 12:32 PM
Hi @kannanni14 that's good news, thanks for letting us know, if you feel like it please mark one of the messages as best answer which will close the issue and save others fretting 🌞
on 04-08-2020 11:52 AM
on 03-08-2020 08:51 AM
Hi @kannanni14 your post has been flagged for assistance and you should hear soon.
