Router powerpack failure
billgraham
Message 2 of 2
Hi, the power pack to my HG635 super router has failed.  No voltage showing on test
It is 12 volt 1.0 amp capacity.  I am using temporay powerback but it has only 0.6 amp capacity.  It will fail also.
I cannot find a way of contacting talktaik to get the correct powerpack replaced.
Any ideas?
Thanks William Graham
1 REPLY 1
Message 1 of 2
I can't order a powerpack individually so I'll do the next best thing and send a new router out to you.
