on 26-03-2019 07:14 AM
During the night we had a power cut, came home and my router is flashing orange switched off and on numerous times left unplugged for a minute also tried resetting, what ever i do my router will not connect always goes to the flashing orange light. We need the wifi working, any help please?
on 26-03-2019 03:30 PM
Hi Walden27
No problem.
on 26-03-2019 03:24 PM
Thank you
on 26-03-2019 11:05 AM
Hi Walden27
on 26-03-2019 10:11 AM
I dont have any other routers no?
on 26-03-2019 10:08 AM
Hi Walden27,
Ok thanks for trying this. Do you have a different router that you can test with? If not then please let us know and we can arrange to send a replacement router for testing purposes.
on 26-03-2019 09:07 AM
Hi Debbie,
I have yes it doesn't seem to do anything feel the little button but it doesn't reset any thing just keeps flashing orange
on 26-03-2019 08:40 AM
Hi Walden27
Have you also factory reset the router using the pin hole reset for ten seconds?
on 26-03-2019 08:24 AM
