on 02-07-2020 10:14 PM
We have recently upgraded to fiber.
We supposed to receive the router, unfortunately our upgrade starts on 7/7 and we haven't received the router yet. Is that normal? Is there anyway to track the router?
on 08-11-2020 05:57 PM
on 08-11-2020 01:41 PM
Hi all
We just upgraded our internet and we would like to return one router to talk talk. Could you please send us a prepaid bag?
Kind regards
on 08-07-2020 08:09 AM
I'm showing the fibre went live yesterday and the sync speed is showing as 71mb.
Have you seen an improvement ?
on 06-07-2020 03:00 PM
Sorry, we are upgrading to fiver, and we have 10 days to test the line. So far our speed downloading is less than 1-2 Mbps while we supposed to have 11Mbps, when the issue is going to be sorted?
advice if the issue will be sorted when upgrading, since it is impossible to use the broadband and Otherwise I will be cancelling the contract
regards
on 06-07-2020 02:07 PM
on 06-07-2020 01:55 PM
Hi Natalia
The service status page can take a couple of days to update to show that the firmware has been updated.
I've reset the data port and optimised the connection and the line is now in sync at 18.2mb.
Please can you monitor this over the next 24hrs and let us know how it compares?
on 06-07-2020 01:41 PM
Hi Debbie
when running the check in the service centre I still receive the alert saying the router needs to update the software.
so far it is the alert received by the talk talk service centre check, not sure if it is correct. What I can confirm is the download speed it is extremely poor with a download of 0.08Mbps
could you please check our line?
on 06-07-2020 01:35 PM
The internet keep dropping and our speed download now is 0.08 Mbps
anything you can do at your end?
on 06-07-2020 12:45 PM
Hi Natalia
Apologies for this.
I've now updated your router firmware version.
What issues are you experiencing with the connection?
on 06-07-2020 12:27 PM
Hi Debbie,
We did receive the router, but still our internet it is pretty poorly.
when running the service check in talk talk website it seems to mention we need to update the router software.
could you please advise?
kind regards
Natalia
on 06-07-2020 10:07 AM
HI Nat19
Apologies for the delay.
I can see that the router was dispatched on 02/07, have you received the router since your last post?
