Router
F10rrell
Message 15 of 15
Can anyone suggest why, when nothing at all has changed, I should keep losing WiFi connection? I have to restart the router 6 or more times EVERY DAY!
Quickly losing patience with it!
Thanks, Lesley
Lesley
14 REPLIES 14
Message 1 of 15
Message 2 of 15
Thanks Debbie-Talktalk 🙂
Lesley
Lesley
Message 3 of 15
Hi Lesley
Thank you 🙂
The WIFI optimisation has now been switched off.
Message 4 of 15
Hi Debbie
I think I've saved that now
Thanks, Lesley
Lesley
Message 5 of 15
Hi F10rrell
Please can you add your name and TalkTalk landline number to your Community Profile.
F10rrell
Message 6 of 15
HI
Thank you for my lovely new router!  Please can I ask that TalkTalk now disable  Wi-Fi Optimisation on my new router?
Thank you for your help
Lesley Orrell
Lesley
Message 7 of 15
Always here to help.
Message 8 of 15
Thanks @Karl-TalkTalk.
Message 9 of 15
Hi Keith,
The router is about 7 years old, so I've a new router on the way to @F10rrell to see if this helps.
Message 10 of 15
I have been struggling to do diagnostics on the WiFi of this HG635 (with all the limitations of the PM system currently). The customer's SSID is not visible in analyser screenshots, so I think this router is faulty.
Message 12 of 15
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar as large images. If they are too small, I will not be able to read them & although I can enlarge them, this just puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so as I can find it easily.
F10rrell
Message 13 of 15
Thank you, your help will be much appreciated!
Does the above help?
Lesley
Lesley
Message 14 of 15
Yes, I can. This is down to Wi-Fi interference where other routers in your area use a wireless channel that interferes with yours. When a router is turned on, if the channel allocation in the router is set to Auto, it scans to try & find the best channel to use. Over time other routers come online or change their WiFi channel to one that interferes with yours. What most domestic routers do not do, however, is to rescan the channels subsequently. This is why it only improves again when you turn the router off & back on again.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
