SAGEMCOM FAST 5364-3.T8 WIFI DROPPING out randomly
GGermanov
Message 4 of 4
Hi guys,
I have changed my router to the latest and greatest SAGEMCOM FAST 5364-3.T8 but since then my WiFi drop randomly devices in my house for no reason including my Fire Stick sits above the router connected to my TV, all devices with wire connection have no issues.
Current Firmware Version: SG4K10002816t
Is there any firmware fixes or something? I will appreciate any kind of help. If there is no fix for this issue I will prefer to get back to my old Huawei Router.
Regards.
3 REPLIES 3
Chris-TalkTalk
Message 1 of 4
Hi GGermanov,
How are you getting on, have you tried splitting the SSID's as ferguson suggested?
FritzCT
Wise Owl
Message 2 of 4
If everything works ok with the old modem/ router then I would switch back to that.
In my experience the Sagem is good for stability but not the greatest in terms of wi-fi coverage.
Fritz
Message 3 of 4
A common way to improve things is to split the SSIDs so that dual band devices do not hunt between bands. Have a look at the help article here:
https://community.talktalk.co.uk/t5/Articles/Split-your-router-s-SSID-wireless-network-name/ta-p/230...
