Sagecom Router DNS Issues
trev Perks
Message 8 of 8
Hi All. I have had a constant Problem with different computers/devices losing connection to the internet. Web Browser shows blank page with suggested DNS problem. If I reset the router the problem goes away and usually happens again a few hours later. If i change the router DNS settings to manual (use google) , this also works for a while. I have read that there is a possible firmware release to address this issue. I think from reading other posts that a different router is the only fix at the moment . Any help would be appreciated .
Trev.
7 REPLIES 7
Message 1 of 8
Glad our Team were able to help.
Message 2 of 8
Good News ! New router has worked without any DNS problems for the last 48hrs. Thanks for the help and fast service.
Trev.
Message 3 of 8
Hi Trev
Thanks for your reply 🙂
The Huawei WIFI hub is on its way, please allow 24-48hrs for this to arrive.
Message 4 of 8
Hi Skynet_TX, thanks for your help. Debbie has offered a Huawei router. I will report back once the DNS problem is fixed to hopefully help other users.
Trev.
Message 5 of 8
Hi Debbie, many thanks for your fast reply.
Yes I would like Huawei hub if it will solve the problem. I have put my TalkTalk landline no. on my profile, if you need more info please let me know.
Many Thanks,
Trev.
Message 6 of 8
Hi Trev
Apologies for this.
I can send you a Huawei WIFI hub, would you like me to arrange this?
Skynet_TX
Message 7 of 8
Hi @trev Perks,
Yes you are correct that there is a new version of firmware that will resolve the DNS issues, that firmware is currently being tested and should be ready for release fairly soon, but a date has not yet been announced.
In the short term the staff here may suggest that they send you a different router, the other Wi-Fi Hub (made by Huawei) is not affected by this problem, they will hopefully be able to respond to this post tomorrow.
