Sagecom wifi disconnections
briantrumpet1
Message 13 of 13
My laptop disconnects from my paid-for TT Sagecom wifi hub once or twice a day while in use, but the TT service checker says it can't recognise my router. Could someone from TT check it from your end, to see if anything needs updating, please?
My community profile is up to date.
Thanks!
12 REPLIES 12
Message 1 of 13
No Problem 🙂
Message 2 of 13
Aha, thanks Karl. Will do.
Message 3 of 13
You can just return the router, it is linked to your account via serial number.
Message 4 of 13
Hi - new router arrived, seems fine, and though there are occasional disconnections on wifi, your line checker tells me it's wifi my end, rather than line problems causing it. At least the router is now recognised, and has the latest firmware, so I'll send back the old one.
I see it says to include the invoice, but I can't find it - does that matter?
Message 5 of 13
I've ordered the router, it should be with you within a couple of days but please allow up to 5 working day for delivery. I'll send you a PM with a link to the survey
Message 6 of 13
OK thanks, I'll sort this out for you now and let you know when I've ordered it
Message 7 of 13
Thanks @Chris-TalkTalk  - yes, sure.
Message 8 of 13
Hi briantrumpet1,
We're trialing a new way of sending routers, would you like to take part in the trial? We would just ask your to complete a short feedback survey afterwards
Message 9 of 13
Thanks Michelle - weird - I thought I'd replied to this!
Yes please to replacement Sagecom - last night, after a couple of days of several disconnections, I lost internet entirely, and it still wouldn't connect this morning, so I reconnected one of my old routers, and it picked up the internet straight away, albeit a bit slower on wifi than the Sagecom.
Message 10 of 13
Hi brian,
Thanks for trying this. I've checked again and I still can't check the firmware. Would you like us to send a replacement router for testing purposes to rule out any issues with the current router?
Message 11 of 13
Thanks Michelle. Reset done.
Just to note, even when I'm on ethernet, Zoom occasionally tells me that my connection is unstable, which is odd, as when everything's going well, it's 37mb/s. Anyway, let's see what you find first.
Message 12 of 13
Hi brian,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault. I can't currently see which router/firmware you currently have. Would it be possible to factory reset the router, set this back up, then let us know so we can re-check this again to see if the firmware is up to date please?
