on 28-04-2021 10:42 AM
Dear community
I have a problem that is getting worse... My Sagem Fast 5364 is dropping the internet connection (no device can connect). Yet, locally accessing the router and its management menus, it is still convinced to be fully connected when there is no internet...
The issue is cured by 'restarting the gateway' through the management sub-menu, which I imagine basically reboots the router. This is however getting worse - for some reason mainly in the evenings. Last night I had to do this 3 times.
Any ideas please?
thanks, Alex
on 20-05-2021 07:24 AM
Hi alex,
Thanks for the update and I'm glad to hear that the connection has remained stable 🙂
on 19-05-2021 08:50 PM
on 13-05-2021 09:16 AM
Hi Alex
The Huawei WIFI hub is on its way, please allow 24-48hrs for this to arrive.
on 13-05-2021 08:48 AM
on 13-05-2021 08:40 AM
Hi Alex
Apologies for this.
I think we should send a Huawei WIFI hub, would you like me to arrange this?
on 13-05-2021 08:26 AM
on 13-05-2021 06:43 AM
Hi alefir3
I can I just check, which router did you receive the Huawei or Sagemcom hub?
on 12-05-2021 10:54 PM
on 28-04-2021 01:24 PM
That's ok, take as long as you need to test, we'll be right here when you need us 🙂
on 28-04-2021 12:50 PM
on 28-04-2021 12:45 PM
No Problem 🙂
Router should arrive in a day or two, test for a good few hours when it arrives and let me know if there is any improvement.
on 28-04-2021 12:17 PM
on 28-04-2021 12:15 PM
I'll swap out the router for you and see if this helps.
on 28-04-2021 11:38 AM
on 28-04-2021 11:26 AM
Can you please add your home phone number or Account number to your Community Profile.
We will not attempt to call you, this is so we can locate your account and run tests on your line if you are reporting a fault.
We will then reply via this thread in our Community with any further advice or next steps.
If unsure of your phone number, and if your line is working simply dial 17070 from your land line phone and this will confirm the number for you. Alternatively these details can be found within My Account online or may be on the heading of any paperwork you have received.
Please post back on this thread when this has been done.
