Sagemcom FAST 5364-3 T8 Router kicks off all other devices when using VPN
Caroline92
Message 13 of 13
When I'm logged in to a VPN (a requirement for work) on my work laptop, the Sagemcom FAST 5364-3 T8 router we have at home kicks every other device off the internet. Between myself and the IT team at work, we have narrowed it down to the router rather than any other sources (the VPN, the laptop etc) as I have successfully used my phone data as a hotspot for all my devices with the same VPN and not experienced the same issue.
Could I be sent a new router please - or is there something I can do to this one to stop this from happening?
12 REPLIES 12
Message 1 of 13
Hi Caroline
Thanks for the Private Message.
Message 2 of 13
Hi Caroline
Apologies, please can you try this again?
Message 3 of 13
Hi Debbie,
I'm struggling to do this as I'm getting an error when I go to private message you:
As you can see there's no option to action any message?
Thanks,
Caroline
Message 4 of 13
Hi Caroline
Please can you send me a Private Message to confirm the name on the account, I can then send the replacement router.
Message 5 of 13
Yes please! That would be great.
Thanks,
Caroline
Message 6 of 13
Hi Caroline
Thank you.
I've checked and your router has the latest firmware version. Would you like me to send a different make and model of router for testing?
Caroline92
Message 7 of 13
Hi @Debbie-TalkTalk - landline has been added.
Thanks,
Caroline
Message 8 of 13
That most certainly shouldn't be the case, as you say. I have never come across such a problem before. Hopefully TalkTalk will be able to help you.
Message 9 of 13
Hi Caroline92
Please can you also add your TalkTalk landline number to your Community Profile.
Caroline92
Message 10 of 13
Hi @Michelle-TalkTalk - I've now done this.
Thanks @KeithFrench, appreciate the feedback. Unfortunately, it's the second half of your advice that is the issue - it's that all the other devices (phone, partner's laptop etc) are no longer able to use the internet at all once I'm logged in via the VPN on my laptop (through the TalkTalk wifi and router). The router seems to be the issue having done an exercise of deduction.
Message 11 of 13
Hi @Caroline92
If the VPN client is on say a PC, when connected, any internet access from that PC will no longer go out to the internet from the TalkTalk network, instead, it routes out via your company's internet access router. You will have no access to that PC from any device connected to your router, whilst the VPN is active.
However, whilst it is active, you should still be able to access the internet from these other devices via the TalkTalk network.
Message 12 of 13
Hi Caroline,
  • Name
  • Telephone number
  • Alternative contact number
