Sagemcom Hub Issues
Theswintons
Message 5 of 5
Hi there, first time post looking for help.
I have a Sagemcom WiFi Hub for my fibre broadband. I have started experiencing problems with the 5ghz WifI AND ethernet connections to multiple devices. Having researched and interrogated the settings the hub says the 5ghz connection is DOWN.
This doesn't explain why suddenly neither a directly ethernet linked PS3/4 or a powerline adapter PS4 won't connect to the hub either.
I have reset the hub (twice) and no change.
I have plugged the 'old' router in (Huawei HG633) and hey Preso! all WiFi and ethernet connected devices are working fine, if a little slower.
Any thoughts?
4 REPLIES 4
Message 1 of 5
No Problem 🙂
Message 2 of 5
Thanks @Karl oce
Message 3 of 5
Hi Theswintons
i'll get a replacement hub out to you and see if this helps.
Skynet_TX
Message 4 of 5
Hi @Theswintons ,
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
If they think the hub is at fault they will be able to arrange a replacement for you.
When you have tried to reset it can you ensure you hold the reset switch in for long enough (10+ seconds until the light goes out) as if you don't hold it for long enough it will just restart rather than actually doing a factory reset.
