Samsung Smart TV and SKY Q Disconnecting from Hub
tommy_l
Message 15 of 15
I have a Samsung Smart TV and Sky Q connected to my TalkTalk WiFi Hub. Recently both have been losing connection to the hub, even though they are connected via ethernet cable. When disconnecting and reconnecting the cables the hub's light flashes orange for a few seconds before a connection is re-established.
I have connected both the TV and Sky Q via WiFi and they will lose connection this way eventually as well.
I would assume this is an issue with the hub and not the TV and Sky Q, since both are having the disconnecting issues.
Anything I can do to resolve this issue? Thanks for any advice.
14 REPLIES 14
Message 1 of 15
The replacement router sent a while back is the same model.  I've a completely different model on the way, one you have not tried before.
Message 2 of 15
@Karl-TalkTalk  I will try anything. I take it that the replacement router I received a few weeks back is the same model as my original one?
Message 3 of 15
Nothing I can think of would cause this, and optimisation is still showing as off.
Would you like to try a different model router to see if this helps.
Message 4 of 15
@Ady-TalkTalk @Karl-TalkTalk @Debbie-TalkTalk
Had a good run but unfortunately suffered the ethernet disconnection again on Monday, both SkyQ box and Samsung TV couldn't connect via ethernet so I had to switch off and on the TalkTalk hub to regain a connection.
Any other ideas? Any settings that can be changed on the hub?
Message 5 of 15
That's great. Thanks for posting back to let us know it's working better.
Ady
Message 6 of 15
My ethernet connections have been fine since I disabled WiFi on the Sky Q box (and possibly combined with what @Karl-TalkTalk did with WiFi optimisation, whaterver that is?)
If I do get the problem again I will respond here, otherwise all good at the moment.
Message 7 of 15
If you can continue to test with the TalkTalk Hub. I've disabled the wifi optimisation on your line for now to see if this will help.  See if things are more stable over the next couple of days.
Message 8 of 15
Hi again @Debbie-TalkTalk.
I connected the replacement router, connected the Samsung Smart TV and Sky Q via ethernet again and both lost connection after a few days, same as what happened with the original router.
I went through Sky Q troubleshooting and it recommended that I disable 2.4ghz and 5ghz wifi on the sky Q box, so I have done this and managed to reconnect my equipment via ethernet and will report back on the outcome.
I have managed to borrow an old BT Hub 6 router, will I be able to use this with my talktalk fibre just to trial so that I can eliminate either my equipment or the router.?
Message 9 of 15
Hi tommy_l
Message 10 of 15
A replacement router would be perfect (🤞), many thanks.
Message 11 of 15
Hi tommy_l
I can send a replacement router for testing, would you like me to arrange this?
Message 12 of 15
The Sky Q and the samsung Smart TV suffers the same issue over wifi and ethernet connections!
Message 13 of 15
Hi tommy_l
I've completed a line test which hasn't detected any faults but I can see re connections on the line.
Do any other devices (laptops, phones) also experience this issue or is it only affecting Sky Q?
Message 14 of 15
With the hub light going orange that would suggest that the router & line are unstable, I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
