Setup second router with VPN
Vasco747
Message 2 of 2
Does anyone know how to setup a second router (in my case GL.iNet GL-MT300N-V2) to work with a OpenVPN Client? I have the OpenVPN client working on my phone and Macbook, but I wanted it to come straight from the Wi-Fi or Ethernet. The problem is when connecting both routers together it doesn't work. At the moment I have an ethernet cable connected from a LAN port on the TalkTalk Sagemcom 5364 to the WAN port on the GL.iNet. The internet works but I it gives me error when I turn the VPN On.
1 REPLY 1
bigkenny
Problem Solver
Message 1 of 2
have you tried Lan to Lan and not Lan to Wan and turn DHCP off on 2nd router
