Since changing to Fibre 35 i now have no internet
Di Andrews
Message 3 of 3
No internet after changing to Fibre 35.
Had 3 service calls with talktalk. Still not resolved.
Reactivated account and reset router, twice, still no internet.
Should we have not changed to Fibre?
Message 1 of 3
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 2 of 3
Hi @Di Andrews,
What make / model of router do you have and what light(s) are showing on it.
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
Also, if you have a landline phone can you check to see if that is working normally (i.e. you have a clear dial tone and no noise on the line). Can you also dial 17070, this will read back the phone number of the line, can you ensure this is the number you expect (i.e. the number displayed in 'My Account').
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
