on 14-04-2022 10:37 PM
I have SKY Q multiscreen; One main box & one mini box.
The mini box keeps disconnecting from the main box, despite having a constant & ok network & internet connection.
When checking the settings on the main Q box, the network status remains good, BUT connection to internet keeps changing from connected to not connected repeatedly.
This doesn't seem to happen all the time, but has been an issue for the last four evenings now, after about 8pm.
I obviously notice it then as that's when the sky boxes are being used.
The two boxes are cable-connected to my network. The connected/not-connected to internet is on the main box only. Mini box is fine.
I've tried wi-fi connection on the main box... Same result.
I'm stuck for any solution.
When the problems started (just a few days ago), I logged into my wi-fi hub to restart it. I think its software has been updated very recently (version SG4K100136)?
I'm guessing it may be a software bug?
Anyway, suggestions please? It's driving everyone in the house absolutely crazy.
on 27-04-2022 07:09 AM
Thanks for the update 🙂
on 26-04-2022 05:03 PM
At the moment everything looks good. All assigned IP's are good & connection is stable.
With any luck I won't have any further issues.
Thank you everyone for your assistance.
Kind regards,
Jonathan.
on 26-04-2022 01:07 PM
Thanks for confirming 🙂
on 26-04-2022 01:06 PM
The pin reset worked, so I can now log in. Cheers.
on 26-04-2022 01:01 PM
on 26-04-2022 12:50 PM
Well, switching off & back on didn’t work. I’ll have to try the reset button. I’ve just checked & I saved my configuration recently, so will hopefully be able to restore it & address any subsequent conflicts. Fingers crossed…
on 26-04-2022 12:48 PM
Ok, let me know what happens.
on 26-04-2022 12:38 PM
I'll try switching it off & back on again first...
on 26-04-2022 12:37 PM
But if I do that, won't I lose all my saved static addresses?
on 26-04-2022 12:35 PM
Don't worry about the t on the end, some firmware versions show this and some do not.
Try a pin reset of the router to factory reset it and then see if it will log in.
on 26-04-2022 12:32 PM
Hi Karl,
It's showing version SG4K100136 [no "t" on the end].
But I can't log into it now. It says "wrong login information"
I've checked & double-checked the password, which I never changed from the printed label on the back of the router...
on 26-04-2022 11:59 AM
Firmware should now show as V136t.
on 26-04-2022 11:43 AM
OK, thanks for confirming, I'll go ahead with the firmware. Router may reboot in the next 5 minutes, don't power off the router.
on 26-04-2022 11:39 AM
Hi Karl,
No, I don't tend to use a VPN at home. Cheers.
on 26-04-2022 11:36 AM
Will do. Currently your on 129t, latest version is 136. Before I go ahead, do you use VPN at all to work from home etc. V136 has an issue with some VPN, so 129 is best if you use this.
on 26-04-2022 11:29 AM
Thanks for the quick reply Karl.
In that case, can you initiate the update to the latest version please? I'd like to check it again.
Many thanks,
Jonathan.
on 26-04-2022 11:15 AM
Its not possible for us to send the firmware, we only have access to the server to initiate a firmware update.
on 26-04-2022 10:45 AM
Hi Debbie,
It's been good thank you. Having checked all of my equipment again, I think the problem may have been with an IP conflict - I'm using a few gigabit ethernet switches throughout the house.
It's quite possible this was the issue, which, to be honest, I didn't check, having assumed it was maybe down to the router firmware update.
Is it possible for you to either send me the 2 firmware versions by email, or send me a link to obtain them?
That way I can experiment between the two, rather than ask for it to be done on here?
Just an idea if it's possible, as I'd like to try the new version again to see what happens now I've resolved the IP conflicts (I think).
Cheers,
Jonathan.
on 25-04-2022 11:51 AM
Hi Jonathan
How are you getting on, how has the connection been?
on 21-04-2022 06:20 AM
Ok thank you and please let us know how you get on.
