Slow 4.5Mbs on a fast fibre connection in the afternoon
IanObr
Message 17 of 17
I am located in Wallasey, Wirral, CH45
Today my speed thorughout the afternoon has dropped to a poor 4.5Mbs when I am paying for 60Mbs
Just me working from home using Teams and Citrix, nothing special.
I have noticed this happen before and expect it will recover back to ~50Mbs this evening. But I need the speed all day!
Screenshot of SpeedTest
Other posts suggest your Network Engineers waive some magic wand and the speed recovers during daytime.
Please waive the wand on my connection.
16 REPLIES 16
Message 1 of 17
Hi Ian
No problem 🙂
Router returns bag is on its way, please allow 24-48hrs for this to arrive.
IanObr
Message 2 of 17
@Debbie-TalkTalk   Please send me a returns bag.
Thanks for your help.
Message 3 of 17
Hi IanObr
If you would like to return a router then we can send you a returns bag?
IanObr
Message 4 of 17
Hi. The issue appears to have resolved itself.
My line speed is now a consistent 40Mbs-ish throughout the day, rising above 50Mbs in the evening.
I am happy with these speeds.
What should I do with the spare router I now have?
Message 5 of 17
Router on the way.
IanObr
Message 6 of 17
@Michelle-TalkTalk  OK. I will try the new router if you send it to me.
Thanks for your assistance so far.
Message 7 of 17
Hi Ian,
Thanks for trying this and I'm sorry to hear that there hasn't been an improvement. The line test is still detecting a possible fault towards the property, although the sync speed looks ok. Would you like us to send a replacement router for testing purposes to rule this out? We would also send a router returns bag so that one of the routers can be returned.
IanObr
Message 8 of 17
@Michelle-TalkTalk  Good morning. I did the 30 minute router power down last night around 10pm.
The speed this morning is still down at 4.5Mbs from a wired device.
What do we do next?
Message 9 of 17
Hi Ian,
Ok thank you and please let us know how your speeds compares.
Thanks 🙂
IanObr
Message 10 of 17
I will power down the router tonight.
During the day I am working and turning it off for 30 minutes is not an option.
Forgot to mention before that all the speed tests I am reporting are through a wired device.
I use a home network through the electric ring main cabling.
I will reply again tomorrow morning when I can check the speed after the router power down.
No point in checking it in the evening as the speed is always up around the 50Mbs at that time.
Message 11 of 17
Ok thank you for confirming. Could you try powering down the router for a full 30 minutes as this will reset the current session and can often increase the throughput speed and then run a wired speed test please?
IanObr
Message 12 of 17
My router is plugged into the main socket.
There are no extension sockets.
I do not have an alternative router to test with.
Just a plain vanilla setup like 99% of your customers must have.
Message 13 of 17
Hi Ian,
Ok. Is the router connected to the main socket? Do you have any extension sockets? Do you have an alternative router than you can test with?
IanObr
Message 14 of 17
@Michelle-TalkTalk   Thanks for looking into my issue.
My main socket does not have a test socket.
Right now the speed is 2.9Mbs according to the TalkTalk Speed Test
Message 15 of 17
Hi Ian,
I'm sorry to hear this and I will take a look now. I've run a test on the line which has detected a potential issue towards the property. Does your main socket have a test socket? If it does then if possible please can you connect the microfilter, router and phone at the test socket so we can re-run the line test again in this set up.
Skynet_TX
Message 16 of 17
Hi @IanObr,
If you go to the Service Centre what does it show for your estimated speed range. If you log into your router to check your sync speed does this show speeds within that estimated range. If you run a speed test (ideally from both a wired and wireless device so that you can compare), how close are the speed test results to the sync speed shown on your router.
