on 21-12-2021 03:50 PM
Hi there,
i’m seeing around 22Mbps or less on my line currently. It was running well until a couple of weeks ago when i noticed some Openreach technicians doing some work on the telegraph pole outside my house.
i’ve tried restating the router, connected a landline phone to check for noise (there is none), and i’ve tried a 3rd Party router (that didn’t help either), any ideas?
on 26-01-2022 08:23 AM
Hi Derwig,
I've sent you a PM
on 24-01-2022 09:08 AM
Hi Derwig
Thanks for confirming your details
Please can you also provide your availability for an engineer visit, AM and PM?
on 24-12-2021 09:36 AM
I've sent you a PM requesting some details.
on 23-12-2021 09:26 PM
Yes please go ahead and book an engineer.
Thanks!
on 23-12-2021 10:20 AM
Tests are passing but we can see drops in the connection and DLM has reduced the speed as a result.
As you have tested with another router, the next option is to progress to an engineer. Would you like to do this now ?
With Christmas just over a day away, then the Bank Holidays, we are looking at next wednesday as the earliest an engineer can be arranged.
on 22-12-2021 09:30 PM
Hi there,
The router is plugged into the master socket so there is no phone cabling between the router and the connection. I restarted the router today after turning off for an hour, that made no difference.
i’ve run a line test which didn’t help and also renamed my wifi network back to the default name when the router restarted 😡. There are no devices nearby that could be causing interference.
The last time i had this issue you had to raise a call with Openreach who fixed the problem without visiting my property.
on 22-12-2021 07:21 AM
Hi Derwig
I've completed a line test which hasn't detected any faults.
I can see re connections on the line and this can affect the sync speed. It also shows - Regular Interference Observed Daily
Is the connection dropping or has the router been rebooted? Is the router located near to any devices that could cause any interference?
on 21-12-2021 08:46 PM
Hi @Derwig,
Have you noticed any issues with the router losing connection and having to reconnect, or is it staying connected ok, but just running slowly.
Is the 22mbps you are seeing the router sync speed, or a speed test result. If it is a speed test result it would be worth logging into your router to check your sync speed, if this is still up at the normal speeds you would expect then try switching your router off for over 30 minutes to force a new session in the street cabinet.
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
