Slow Fibre Once Again
aliomar
Message 4 of 4
Speed has been horrible for almost 2 months;
I am supposed to be getting a consistent 65mbps download and around 20mbps upload, whenever I have a fault, the same thing happens "theres seems to be a problem with the line, were gonna send an engineer". The BT engineer comes and does his magic and boom the speed is backup to normal for 1 or 2 months and then the cycle goes again and again. Im tired of this. So once again can an OCE please check my line again for any issues.
Questions:
Is the phone still working?  yes, working perfectly
have I reset the router for 30 mins? yes multiple times to no avail
have i changed any equipment since the last engineer visit? no I have not
Have I tried using a test socket? I only have a master socket and will not open it in case i break it
Have i used a different router? Yes I have a spare hg633 which syncs at the same sub par speed.
Are you using wireless or wired to test the internet? All tests are done via ethernet directly to the ports on the router at a time when there is no network traffic
If an OCE reviewing this has anymore questions to ask then go ahead. I request an engineer to come as soon as possible to sort my line out once again. Thanks
3 REPLIES 3
Message 1 of 4
Hi aliomar
This socket does have a test socket, there should be 2 clips on either side of the master socket which allows you to remove the face plate.
Message 2 of 4
its this one
Message 3 of 4
Hi aliomar
I've completed a line test which hasn't detected any faults and your line is in sync at 41.3mb
Would it be possible to post a photo of your master socket?
