Slow broadband speed due to noisy line
CaptJohn
Message 23 of 23
My broadband speed has recently (within the last month) slowed down from about 30 Mbps to 9Mbps. Having contacted the TalkTalk technical department they keep wanting to send me a new router and/or wait 48 hours. None of this will work due to the reason that I have had this problem before and I know the solution.
More than once in the past my broadband speed has decreased due to noise on the line. Accordingly the broadband speed decreases automatically in order to work through the noise. When the line is cleared of noise the broadband speed does not automatically revert to the optimum speed as this has to be done manually.
I have this information on good authority from a BT Openreach engineer.
The TalkTalk technical department is not interested in my comments and will take no notice of what I say. They think that a new router is the solution. I suppose it's cheaper than calling in BT Openreach to fix the problem but it just doesn't work. Waiting 48 hours and monitoring the speed doesn't work either as nothinh changes.
22 REPLIES 22
Message 1 of 23
If it happens again you can just deal with us if you prefer rather than going through chat
Unfortunately we do have to go through some diagnostics initially even if the issue appears to be the same as before, we can't just assume that it's the same issue.
It really up to you which router you send back, it doesn't really matter to us 🙂
Message 2 of 23
Thanks Chris
So the new router I was sent did not resolve the problem. It looks as though there was nothing wrong with the existing router.
I can either send back the old one or the new one. It's up to you.
If this problem happens again (and I believe it was caused by noisy contacts on the BT master Socket) how can I avoid the usual response from TalkTalk which begins with asking me if I switch the router off and on regularly (which I don't) and then sending me a new router (which doesn't fix the problem). The next stage is time wasting which asks me to wait 48 hours (which doesn't resolve the problem) then wait another 48 hours (which also doesn't resolve the problem).
All this is happening when I communicate via "Chat".
When I contacted "Community" I got a much better response from yourself.
Message 3 of 23
Hi CaptJohn,
Glad to hear your speed has improved. The line management system (DLM) lowers the speed if the number of disconnections and/or errors fall outside predefined limits for a set period of time so it will be either disconnections or errors (or both) that caused DLM to reduce your speed
Message 4 of 23
Hi Chris
TalkTalk email has been down since last night but it's now up and running.
I've done as you requested - turned router off, waited at least 30 minutes and switched it back on again.
Checked the speed and now it's:
Download - 26.7 Mbps
Upload - 6.4 Mbps
So a vast improvement on before. It took quite some time to get back to this speed but now I know to contact "Community" and not the technical Chat line.
Can you tell me why the speed reduced to 10 Mbps and why it does this every so often?
Message 5 of 23
Hi CaptJohn,
Thanks for the PM, sync speed is still 30Mbps so can you switch your router off for at least 30 minutes then switch back on and retest - please let us know how you get on
Message 6 of 23
Communication between myself and the OCE team seems to have ground to a halt.
Have all possibilities to resolve my problem been exhausted?
My download speed is now 11 Mbps and upload 6.5 Mbps.
Is it possible to get my speed back up to the level that it was a few weeks ago which was around 30 Mbps?
Is it possible to find out the outcome of the investigations of the BT Openreach engineer yesterday?
Did he actually appear?
Message 7 of 23
Hello Michelle
OCE_Chris has been dealing with this case for sometime now and has declared that there is a potential fault. BT Openreach has been called in to investigate and will be in attendance from 0800 to 1300 today.
The fact is that, fault or not, the broadband speed has dropped from a consistent 30 Mbps to a consistent 9 Mbps.
As I have explained many times now the likely cause of this is (or was) noise on the line which may be audible or inaudible. This causes the line speed to decrease to compensate and once the noise has cleared the line speed has to be reset to its optimum rate. This was explained to me by a BT Openreach engineer and TalkTalk seems not to be aware of this process.
Message 8 of 23
Hi CaptJohn,
Our network team have booked the engineer visit for 29/01/2019 AM (08:00-13:00) - please let us know how you get on.
Message 9 of 23
Hi CaptJohn,
Thanks for the PM. I've passed on your availability to our network team, we'll let you know when we receive confirmation of the date and time slot booked.
Message 10 of 23
Please see my PM.
Message 11 of 23
Hi CaptJohn,,
Thanks for the PM, I've replied requesting a bit more information
Message 12 of 23
Hi CaptJohn,
I've replied to your PM
Message 13 of 23
Hi CaptJohn
The next step will be to arrange a BT Openreach engineer visit.
Message 14 of 23
Hi CaptJohn
I've escalated this fault over to our Network Team and I will post back on this thread as soon as I receive further information.
Message 15 of 23
The landline is still clear when making calls. I'm still plugged in to the test socket. The router has been on continuously.
Message 16 of 23
Hi CaptJohn
Apologies for this.
I've checked and I can see that the sync speed hasn't increased. Is the landline still clear when making calls?
I can then raise the slow sync speed fault over to our Network Team for investigation.
Message 17 of 23
The download speed is 9.3 Mbps and upload 6.7 Mbps.
No change then!
Message 18 of 23
Hi CaptJohn
Thank you. Please can you post back on this thread on Wednesday and we can check the connection stats again.
Message 19 of 23
DSL filter now plugged into test socket (so that I can still use the landline).
Message 20 of 23
Hi CaptJohn
If the line is now clear then we can focus on the broadband connection.
Would it be possible to connect the router at the test socket for 48hrs without rebooting to see if DLM now starts to change the profile and increase the speed?
