on 19-05-2022 09:46 PM
I've noticed recently that my internet connection to my work laptop ( vpn connection ) has slowed down. My wife is also having issues at home with connecting to her work laptop ( vpn connection as well) and at times we have been forced to tether to our mobiles. These issues have only started happening recently and i'm wondering if my router has recently received a firmware update?
I'm pretty sure it has and if this is the case can you revert the firmware to the previous version. Currently my router is on version SG4K100136.
on 20-05-2022 01:43 PM
Hi marksc
We can try one more factory reset? My only worry is we break the router if the update keeps failing.
on 20-05-2022 01:36 PM
Is it an issue at your end with the update. Could one of you're colleagues try to update the firmware?
on 20-05-2022 01:33 PM
Hi marksc
We can usually just update/change the firmware on the router but I'm having issues updating your firmware. It is stopping me completing all the steps I need to take to put you on a different firmware version.
Apologies for this.
on 20-05-2022 01:28 PM
I can try the other router but surely its possible to change the firmware especially when it has successfully been updated.
on 20-05-2022 01:25 PM
Hi marksc
Thanks for confirming this. The firmware updates are still failing.
Would it be ok to test with the router I have sent when it arrives please?
on 20-05-2022 01:19 PM
Hi Debbie - router light is a solid white
on 20-05-2022 01:01 PM
Hi marksc
I'm still having the same issue with the firmware, apologies for this.
What light is now showing on the router?
on 20-05-2022 12:39 PM
Hi marksc
Great thank you. I'm trying again with the firmware, please can you leave the router switched on now.
on 20-05-2022 12:35 PM
Hi Debbie and - that's been done
on 20-05-2022 12:21 PM
Hi marksc
Could you try a pin hole reset for me for ten seconds please?
on 20-05-2022 12:18 PM
Hi Debbie
I had turned off the light on the hub and when I try to log on to router it's not recognising my credentials so maybe it's been reset?
on 20-05-2022 12:14 PM
Hi marksc
Can I just check, what light is showing on the router at the moment?
on 20-05-2022 12:12 PM
Hi Debbie
Can you try again. I know firmware updates have been successful for others. I'd like to continue using the hub router as prior to firmware update things were fine.
on 20-05-2022 12:08 PM
Hi marksc
I'm really sorry, the firmware update has failed and I can't connect to your router.
I have sent out a new router, this is a different make and model and will work ok with VPN.
You should receive this within the next 24-48hrs.
on 20-05-2022 09:14 AM
Hi marksc
No problem 🙂
on 20-05-2022 09:08 AM
Thanks Debbie
on 20-05-2022 09:07 AM
Hi marksc
Yes no problem 🙂
I will start the the update at 12 today and post back to confirm once this has been completed.
on 20-05-2022 09:02 AM
Hi Debbie,
If you could make the change to the router between 12pm and 1PM that would be great.
on 20-05-2022 08:35 AM
Hi marksc
Apologies for this.
I will need to make a change to your router firmware, when would be the best time to do this?
We advise to leave the router switched on without being rebooted whilst we update the firmware, this should take no longer than 15 minutes to update.
on 19-05-2022 10:20 PM
Hi @marksc,
SG4K100136 is the newest firmware, that has only been rolled out fairly recently, the support team here will be able to help more tomorrow.
