Slow fibre speeds
domdorris
Message 23 of 23
Hi, my fibre link speed is no longer 39mbps, it's dropped to 25mbps over the past couple of months. I've repeatedly called about it, ran all the tests and usual diagnostic stuff. I've had the engineers out too and I'm getting really bored with continually having to complain about it .
Please help,
Dom
22 REPLIES 22
Message 1 of 23
Hi Dom
The next step will be to arrange a BT Openreach engineer visit.
Message 2 of 23
Hi Dom
Thank you 🙂
I will post back on this thread as soon as I receive further information.
Message 3 of 23
I'm happy for you to proceed Debbie, thanks
Message 4 of 23
Hi Dom
Are you happy for me to raise this straight over to our Network Team now or wait to try at the test socket again?
Message 5 of 23
Sounds like a good plan since there's no difference when connected to the Master Socket 5C's test socket .
Many thanks Debbie
Message 6 of 23
Hi Dom
If the connection is still dropping with the router at the test socket then I will pass this straight over to our Network Team. This testing will help rule out any possible issues with the face plate or internal wiring.
Message 7 of 23
No I didn't use the test socket but I'll do that now. The supplied cable is too short for me to use so I have a dedicated longer cable. I did change the filter to one of the supplied ones.
Message 8 of 23
Hi Dom
Did you connect the replacement router at the test socket? Did you also use the new cables and filter?
I can then raise this over to our Network Team for investigation.
Message 9 of 23
Hiya Debbie,
Yes I'm afraid so. I've restarted the Router only once since install so that I could move some wiring but that's it. The line speed is now less than 15000kbps which is way down from the 39999kbps that I had. According to the router, the line is capable of 75999kbps although, I don't have the faster plan.
Message 10 of 23
Hi Dom
Is the connection still dropping with the replacement router? (I can see re connections on the line)
Message 11 of 23
Hi Debbie, thanks for the advice, I certainly hope it does improve since it has now dropped again down to 16495kbps!
Message 12 of 23
Hi domdorris,
Thanks for the update. It can take between 24-48hrs for DLM to start making changes to the sync speed if the connection remains stable. Could you bump your thread tomorrow morning and we can re-check to see if DLM has made any changes to the sync speed.
domdorris
Message 13 of 23
Hi Debbie,
New router arrived and set up.
I'm afraid the speed is still slow....it's now down to 17999kbps😭
Message 14 of 23
Message 15 of 23
Ok Debbie, will do.
Many thanks.
Dom
Message 16 of 23
Hi Dom
The HG633 router is on its way, please allow 24-48hrs for this to arrive.
domdorris
Message 17 of 23
Hi Debbie, the D-LINK router replaced the HG533 router that I used to have but if you think that this is the best course of action, then yes order another please .
Message 18 of 23
Hi Dom
I think we should send a HG633 router for testing purposes, would you like me to arrange this?
Message 19 of 23
Hi Debbie,
Sorry I'm at work just now so can't confirm absolutely what the router model is but I think it's the d-link 3782. It's not currently connected to the test socket as having an open socket is a hazard in our home. In previous tests, speeds while connected to the test socket haven't been much quicker .
Message 20 of 23
Hi Dom
Is the router at the test socket? Which router are you using? (make and model)
