Slow internet speeds
Dai-garw
Message 19 of 19
Hi, faster fibre running below 2mbs again ?  No change to set up, pleas advise what’s going on?
thank You.
18 REPLIES 18
Message 1 of 19
Just checking in to see how the speeds have been over the last few days? 🙂
Message 2 of 19
Dai-garw
Message 3 of 19
Thank you Michelle,
 I’ll keep checking over the next few evenings,
Message 4 of 19
Our Network Engineers have identified an issue and made a change. Please let us know how the evening speeds now compare going forward.
Message 5 of 19
I've raised this over to one of our Network Engineers now and will post back as soon as I know more.
Dai-garw
Message 6 of 19
Hi Chris,
not that I’ve noticed, why would that make a difference if the drop is in the evening / night ?
Message 7 of 19
Hi Dai-garw,
If you switch the router off for 30 minutes in the evening when the speed is low does the speed increase?
Dai-garw
Message 8 of 19
Thank you Gliwmaeden2, screenshot uploaded
Dai-garw
Message 9 of 19
Gliwmaeden2
Message 10 of 19
Screenshots should upload OK on a mobile if you click on this icon in the row of options at the top of the area where you are typing your post, @Dai-garw:
 I use that, as I don't see a camera icon.
Compensation is only automatic for complete loss of service, but if faults and intolerably poor speeds (below the guaranteed minimum for your line) continue for more than 30 days after reporting, you should be able to leave without penalty.
Dai-garw
Message 11 of 19
Hi, how do I go about getting compensation for this poor service,  no more try this try that, I used to get the service I am paying for, nothing has changed my end with my set up etc, I’ve tried to upload a screen shot of tonight’s measurement - guess what, file type not supported.  0.7mbps is the reading, I can email it if you need to see it.  Can you help get this sorted or at least compensate for the misery it’s causing.
Thank You
Message 12 of 19
Hi Dai-garw
Please can you run a wired speed test this evening using the TT speed tester so we can see the results?
Can you also ensure that no other devices are connected and in use when running the speed test.
Dai-garw
Message 13 of 19
Hi Debbie,
ran the test this morning and yes it’s running at 37 - 38.  The issues happen in the evening  / night.
Message 14 of 19
Hi Dai-garw
I've completed a line test which hasn't detected any faults and your line is in sync at 38.3mb.
Please can you power down your router for a full 30 minutes and then run another speed test?
Dai-garw
Message 15 of 19
Ok Keith - thank you
Message 16 of 19
I'll ask TalkTalk to investigate then.
Dai-garw
Message 17 of 19
Both, I’m running WIFI, my son is using a wired connection - had the same issue a few months ago that lasted about a week, always in the evening / night
Message 18 of 19
Have you logged on to the router & checked the speed there? If you have one of the WiFi hubs, this is in the initial dashboard area.
How do you connect to the router, via a wireless or wired (Ethernet) connection?
Which make/model of router are you using?
