Slow speed i was guaranteed 70 mbps but getting only 36 mbps please help
suresh08
Message 6 of 6
Hi I was guaranteed 70mbps speed but only getting 36mbps kindly please help
5 REPLIES 5
Message 1 of 6
Hi suresh08
I've checked the connection stats and your line is in sync at 79.9mb
Please can you power down your router for a full 30 minutes and then run a speed test following this?
Message 2 of 6
Yes when I logged in router it says 80mbps speed
Message 3 of 6
Sorry, but your last post was not very clear.
Do you mean that the router displayed 80Mbps, but a wireless speed test recorded 36Mbps?
Message 4 of 6
Sagemcom fast 5364 and it says 80mbps speed wireless connection
Message 5 of 6
What make/model of router do you have? What is the speed quoted by the router when you log into it. I assume these are speed tests that you have done, are they on wireless or wired (Ethernet) connections to the router?
