on 23-07-2019 09:32 AM
After moving house and spending what seemed my entire life on the phone to your call centre trying to get reconnected, I'm finally back online but getting widely varying speeds.
This morning it was 6mbs and a bit later 17. Last night it was 27 which is the fastest its been but still quite a way off the guaranteed speed of 35
Can you check the profile please?
on 23-07-2019 11:14 AM
on 23-07-2019 11:10 AM
OK thanks, what device are you running the speed tests on? How does it connect to the router (wifi, ethernet cable, powerline adapter)?
on 23-07-2019 11:00 AM
on 23-07-2019 10:32 AM
Hi Loofah,
I'm sorry to hear you're unhappy with your speeds
Your current sync speed is 28.7Mbps. Are you experiencing any problems with your telephone service such as noise on the line?
