Slower Faster Broadband
AP1234
Message 19 of 19
Can someone check or reset my faster fibre speed back to 67mb please?
Its now around 52mb, but feels more like 20mb.
I have checked/restarted all my equipment etc...
18 REPLIES 18
Message 1 of 19
Unfortunately we don't have any control over profile changes as this is managed by DLM. It's possible that DLM will increase the speed back up again if the connection continues to remain stable.
Message 2 of 19
When i joined to talktalk i had 67mb speed, its never dropped until recently.
You said my line in stable, cant you set it back to the 67mb speed profile please?
Message 3 of 19
Hi AP1234
Thanks for the Private Message.
The predicted speed range for your line is showing between 67 and 45mb, with a minimum guaranteed speed of 38.3mb.
Your current sync speed is within the predicted range for your line.
Message 4 of 19
I have sent to a PM Debbie.
Message 5 of 19
Hi AP1234
Apologies for the delay.
I've checked the connection stats and your line is in sync at 52.6mb.
I'm just sending you a Private Message to confirm some details so I can check the predicted speed range for your line.
Message 6 of 19
The new router is stable for over 4 days, and has not dropped.
Speed has not gone back up to 67mb though ;-(
An ideas please?
Message 7 of 19
Hi AP1234,
Thanks for the update. It can take DLM between 24-48hrs to make changes to the speed if the connection remains stable. Would it be possible to post back in 48hrs and we can re-check the connection stats again to see if DLM has made any changes to the speed?
Message 8 of 19
I have plugged the new router in last night into the test socket.
The speed is around 52mb now, but still way off the 67mb i had.
Message 9 of 19
In most cases the router is delivered next day.
Message 10 of 19
Any idea when i will receive the new router, will it be tomorrow?
Message 11 of 19
All tests are clear, but the profile has lowered.  There have been 4 profile changes in response to errors.
I've a new router on the way so this can be ruled out.  When the new router arrives, connect with the new cables and we can then see if the errors reduce and the profile will increase over the next few days.
Message 12 of 19
Any news on this please?
Message 13 of 19
Sorry forget to mention you might have seen reconnects, that was me turning off the router and on again on Saturday to see if it made any difference.
Message 14 of 19
You may have seen some reconnects.
Out of frustration with the decreasing speed, i have now plugged the router into the test socket.
I am sure my internet never drops, as i have not encounteed any loss in service.
The only thing is the line speed is dropping, which we erally notice more and more now with spinning wheels and continuous buffering when wathcing Netflix / youtube etc.
What else can i do? I know in the past when i had ADSL, DLM was reset for me, and issue went away, and speed went back to normal.
Please help
Message 15 of 19
Hi AP1234,
The line test is clear, however I can see re-connections on the line. Just to confirm, do you mean that the router is connected to the test socket behind the faceplate? I've included a Help Article below.
Your guide to master sockets
Message 16 of 19
Hi yes, the router is connected straight into the BT socket.
I did what you suggested, but now as you also know the speed is 51.4mb.
It used to be rock solid at 67mb. My router has not changed or moved position, so i cant understand why the speed has dropped even further.
Are you able to reset DLM, or put my connection back onto the 67mb profile please?
I am sure my line must be ok, before i came to talk talk i was with BT, and had a rock solid connection of 80mb.
Message 17 of 19
Hi AP1234
I've checked the connection stats and the speed has dropped to 51.4mb. The line tests are clear, no faults detected.
Is the router connected at the test socket?
Message 18 of 19
Hi AP1234
I've checked the connection stats and your line is in sync at 57.9mb. No faults have been detected.
Please can you power down the router for a full 30 minutes and then leave the router switched on (without rebooting) we can then check the connection stats again on Monday to see if DLM has made any changes to the line speed/profile.
