on 01-07-2022 11:04 AM
On 11 May , TalkTalk technical help changed my Router Channel as I was getting very poor and degrading speeds during each day. Effect was good and speeds of 36 mbps achieved until last week when problem returned. Now max speed after rebooting router is 25 mbps which gradually decays to 1 mbps by evening, by which time nothing works! I cannot reboot every day, so is router defective? TalkTalk must do something soon or I shall depart. Help please.
on 06-07-2022 10:41 AM
@Bullers, the emails that come from the forum are for notification purposes only, and so it is a No Reply address.
You would always need to sign into the community whether to post a response or respond to a PM.
on 06-07-2022 10:32 AM
OK, no problem, I'll order it now
on 06-07-2022 09:02 AM
Thanks for email Chris, a bit confusing that you cant see my emailed response, but yes please, do send another router for test
purposes.
on 06-07-2022 08:56 AM
Hi Bullers,
I'm sorry but we don't see email replies, only replies in the Community
I can send another router to test with, would you like me to arrange this?
on 06-07-2022 08:30 AM
Hi, in response to last msg from Chris and email from him, I responded by email to say I do not have another router. What next please?
Speed less than 1mbps this morning, router off and on, no 20mbps but I know will fade during day.
on 05-07-2022 10:48 AM
OK thanks for trying that. Do you have another router that you can test with?
on 05-07-2022 10:39 AM
Hi, For the last 3 days I have switched off my router for a minimum of 45 mins. each time in the morning. as suggested by Chris last Friday.
Speed on switch on goes up to 24 or 25 mpbs which then decays to 12/13 after a couple of hours, then 1/2 by evening. This is not good and driving us all mad. Is the router not up to this, is it U/S or is it simply that TalkTalk cannot provide its promised service? My settings etc in the house worked well for several weeks, no new equipment has been installed. TT speed monitor suggests 44 mpbs, independent monitor tells me 14. Help pse.
on 01-07-2022 12:01 PM
OK thanks 🙂
on 01-07-2022 11:55 AM
Thanks Chris, will do. Fingers crossed.
on 01-07-2022 11:51 AM
OK could you switch your router off and leave it off for at least 30 minutes, then switch back on and monitor to see if the issue reoccurs. Please let us know how you get on
on 01-07-2022 11:46 AM
Everything connected to router is affected, TV connected by ethernet, PC and phone by wifi. Its the degradation of speed post
re-booting which is daily problem.
on 01-07-2022 11:38 AM
OK thanks. Line test is clear. Are both devices connected to your router by Ethernet cable and wifi affected by the drop in speed?
on 01-07-2022 11:27 AM
Thanks Chris, all done.
on 01-07-2022 11:21 AM
Hi Bullers,
I'm sorry to hear that you're experiencing problem with your service. Can you please update your community profile to include your:
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
