Snr
kevinwh
Message 10 of 10
My snr is 26 how do I get this fixed on my broadband line. I'm getting 6 to 7mbps download and 17mbps uploaded on a 65 fibre package
9 REPLIES 9
Message 1 of 10
No need to apologise @Chris-TalkTalk the remark was I think aimed at me. Although I fail to see how I was "sharp" either?
@kevinwh I was only answering your question about an SNR reset and trying to move things forward. The current high SNR margin indicates a serious noise on the line issue. The support team are trying to establish whether this might be caused on the voice side. If you can check as they suggested this will help them to help you.
Message 2 of 10
You're in the right place, I'm sorry if you feel it was a bit sharp, it wasn't my intention, we're happy to help 🙂
Message 3 of 10
That was a bit sharp... I think I'm in the wrong place..
Message 4 of 10
Hi kevinwh,
As ferguson has said, we need to look at the underlying problem. Are you experiencing any problems with your telephone service?
Message 5 of 10
No and that won't fix the underlying problem. It happens the other way around: once any issues is resolved then the SNR margin should fall. Please respond to the question asked by Michelle which will help to move this forwards.
kevinwh
Message 6 of 10
Can you not do a snr reset.
Message 7 of 10
Thank you. I've run a test on the line now which has detected a potential fault, the connection looks unstable and the sync speed has dropped. Are you experiencing any issues with the voice service such as noise on the line or no dial tone? If the voice service is ok then we can focus on the broadband connection.
kevinwh
Message 8 of 10
I have updated my information
Message 9 of 10
  • Name
  • Telephone number
  • Alternative contact number
