Speed Boost TalkTalk
Nadifa136
Message 1 of 3
Hello, i upgrade after moved home to fibre broadband plus speed boost, actually i get around 44 mbs down and 12mbs up
After talk talk broadband speed check i tried check my line and results was speed under estimate speed (speed around 60 mbs)
I tried to switch off the router for 30 minutes but nothing changed.
It's any tips for getting the best speed?
Thank you Igor
Divsec
Message 2 of 3
Hi Igor, welcome to the community your post has been flagged for assistance and you should hear during tomorrow.
Please check your community profile and add your landline phone number if necessary it is used to identify your account.
Are your speed tests wired or WiFi? WiFi is typically slower than wired.
Do you know your sync rate as this is actually what TT are talking about.
Message 3 of 3
The line is in sync at 48mb.  This is within the estimated speed range for the line.
Estimated speeds are 36 - 58mb with a minimum guaranteed speed of 31.2mb, so the line is performing as it should.
