Speed Throttling Midday
Tired21
Message 6 of 6
Im receiving severely restricted internet speeds during the daytime which is conflicting a great deal with my work. Were on Fibre 65 I believe.
Early Morning and Evening have been fine, but the bottom is completely dropping out during the day. Given I am attempting to stream, 0.25mbps upload is a non-starter.
Please find attached the speed test record from 02.12.21 11:59.
Please advise.
5 REPLIES 5
Message 1 of 6
OK, based on the test failure I'm seeing, I cannot be sure this is not impacting the connection, so I've logged this over to Openreach to take a look and clear the fault before we take things further.
Check back in 24hrs and we can see what Openreach have done.
Message 2 of 6
I don't have or use one Karl.
Message 3 of 6
Fibre test is clear but I'm detecting a possible fault on the voice side.
Can you check the home phone and tell me if there is a clear dial tone on the line ?
Message 4 of 6
Hello Karl,
This should be done now.
Message 5 of 6
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
