Speed Throttling
stevesuk
Message 24 of 24
I have Faster Fibre with Speed Boost. When first installed I had 50mbps speed and now it's dropped to under 40 and will never go above that, even after reboots. So, I'm a bit suspicious! My attachment shows what I'm getting and what I'm expecting. Admin, please can you look into this.
23 REPLIES 23
Message 1 of 24
The estimate for your line is 35-54mb and the router is in sync at 41mb, so within the estimated range.
All tests are clear, nothing stands out.
Have you checked with a phone handset for any noise / crackles on the line ?
Also, have to tested the sync speed from both the sockets ?
Message 2 of 24
I have been through my emails and there are non quoting expected speeds.
Message 3 of 24
Ok thank you for confirming this. Is the router usually connected at the main socket or an extension socket? Were you provided with a predicted speed range for the line?
Message 4 of 24
The line coming out of the main socket goes to a pre-filtered socket (would that be FTTC) located near my router.
Message 5 of 24
NON-NTE. i.e. no horizontal bar.
Message 6 of 24
Afternoon,
I can't open the attachment, does it look like any of the sockets in the below guide?
Your guide to main phone sockets
Message 7 of 24
I do not have a test socket. See attachment.
Message 8 of 24
I'm sorry for the delay. I've re-run the line test now which hasn't detected a fault and I can see that sync speed hasn't increased. Does your main socket have a test socket? If it does then would it be possible to connect the new microfilter, router and phone directly at the test socket for 24-48hrs so we can see if DLM makes any changes to the speed in this set up please?
Message 9 of 24
Let's be clear on this in that I am paying for a 67mbps package and also it's not a psychological problem at all. Somebody needs to answer as to why the speed has dropped ... same box same place same everything ... nothing has changed at my end.
My sync speed is not currently over 50. It was when installed but has not been since I noticed the speed drop ... everything is 10mbps less than at installation. The pics I included earlier that showed 50mbps sync speed was from way back not as it is now.
To be clear I've attached the latest info.
Message 10 of 24
If your sync speed is still over 50Mbps but throughput still consistently less than 40Mbps, that does seem a bit odd. Perhaps staff will be  able to look into the issue further now that you have ruled out the router as the cause.
To be fair though, the speed you are getting is still good enough to do pretty much anything anyone would want to on the internet (my personal opinion of course). The problem is just a psychological one in that you know you should be able to get a faster speed.
Message 11 of 24
Absolutely none whatsoever. I didn't think the new router would help. It's a standard first try at any problem. Bit annoyed that speed could go down that much, really without me noticing.
AllyM
Insightful One
Message 12 of 24
@stevesuk , Was there any improvement with a different router?
Message 13 of 24
Thanks Steve
Message 14 of 24
Ok, thanks.
Steve.
Message 15 of 24
Hi stevesuk
Ok, I've ordered a replacement router so we can rule this out.
Please allow 24-48hrs for this to arrive. Let us know how the connection/speed compares with this router connected.
Message 16 of 24
Never varies and is always roundabout the same all day. Last night, after 11pm, was when I conducted the latest speed test after switching off the router for 30 mins. Just done another one and download is 40.1 mbps.
Message 17 of 24
Hi stevesuk
Is the drop in speed the same all throughout the day or only at peak times?
Message 18 of 24
You can if you like but I don't think this is the problem and we'll only end up back here still with the same issue.
Message 19 of 24
Hi stevesuk
Would you like me to send a replacement router for testing so this can be ruled out?
stevesuk
Message 20 of 24
Router off for over 30mins. New speed test from a wired, NOT Wifi, connection. Not the expected improvement (see attachment). Hardware etc has not changed ... nothing is different from when it was > 50mbs. Speed has just gone! The router is not syncing at the speed you quote anymore. I may have confused you as the screengrabs I enclosed in 'talktalk1.docx' are the speeds I WAS getting when the service was installed NOT what they are now.
