Speed better without master socket?
lauraabeth
Message 10 of 10
I’m in the process of leaving talk talk as I was supposed to be getting speeds of 39mbs and was getting between 10-20mbs which kept dropping then going up every speed test.
However I decided to try plugging my router into a normal telephone socket (which I know is supposed to cause a drop in speeds with fibre) and I am actually getting  huge improvement in my speeds. The past speed checks I have done I’ve got 30-37mbs every time.
Does anyone have any ideas why this is?
Thanks in advance, Laura
9 REPLIES 9
Message 1 of 10
Hi Laura
That socket is the usual NTE5 BT Master socket.
Just want to check something with you.  If you have a home phone available, and you take the front off this socket, do the other sockets go dead - eg.  No dial tone at them.
Message 2 of 10
Hello, this is what I’ve got that is causing the problems. I removed the faceplate and plugged it into the test socket and the speed still keeps dropping. So do you think the socket needs replacing?
Thanks Laura 😊
Message 3 of 10
If the master socket is the true master socket - ie. the point where the phone line enters the home, then this should have a test socket within.  The Fibre socket has a filter fitted and it is possible the filter could have become faulty.
If you look at the master socket does it look like the picture below :
You can usually remove the face plate and filter and connect a router with a filter directly into the test socket inside.
Karl,
Message 4 of 10
Hello 😊 Any update on why the master socket would be causing the speed issues. I would be happy to stay with talk talk if this is something that can be fixed.
Thanks, Laura
Message 5 of 10
Hi Laura,
Thanks for letting me know.
Message 6 of 10
I checked it this morning and its still ok, got a speed of 36.5mbs.
Thanks, Laura 😊
Message 7 of 10
Hi Laura,
Ok thanks for the update. Is the speed still ok at the moment?
Message 8 of 10
thank you for getting back to me. I have just plugged it into a separate socket, one without two plates on. What a telephone would plug into. Sorry if that doesn’t make sense.
Thanks, Laura 😊
Message 9 of 10
When you say a normal telephone socket, do you mean a completely different socket with your home, or have you removed or changed the filter in your phone socket etc ?
