Speed cap
Michael781
Message 30 of 30
After a constant 67 mb speed i renew nu contract to 65 fiber and my speed is droped to 50 mb/s. I tried to speak with one of the adviser and told me that this speed is supporting the exchange. It is interesting how for one year was fine with more then 60mb and now is different. It is clear the speed is caped.  Can anyone please remove this and put it as was and suppose to be to this type of contract. Fiber 65?
Regards.
Mihai
Michael
29 REPLIES 29
Message 21 of 30
 this was my speed before to put the. filter as you requested
Michael
Message 22 of 30
Hi. I setup the filter now at 20:30 I will live this there for 48 hours. If is no change in my speed is clear is not from my house. It is interesting how this speed was downgraded jus a mount before to swap the contract to fiber 65 to speed of 50mb/s.
 this is my speed on my router at this time. Let's see in 48h
Thanks for the advice let see what will happen.
Regards.
Michael
Message 23 of 30
Thank you. I've run a test on the line which hasn't detected a fault. Does the main socket have a test socket? If it does then would it be possible to connect the microfilter, router and phone at the test socket for at least 48hrs so we can see if the speed increases any further please?
Message 24 of 30
Updated
Michael
Message 25 of 30
  • TalkTalk Telephone number
Message 26 of 30
I have switched off the ruter more then 6 hours this night. In the morning same speed shows.  Down 50.3 / up 17.7
Michael
Message 27 of 30
Hi Michael781
  • Name
  • Telephone number
  • Alternative contact number
Message 28 of 30
I will try tonight a full night power off and I will plug in back the ruter tomorrow morning I will check to see if that change something.
Thank you for assisting me at list. I will be back with the outcome tomorrow.
Michael
Divsec
Message 29 of 30
Hi @Michael781 not a speed cap, for sure. Have you had any disconnections recently? This can cause the DLM system to try to achieve stability at the expense of speed
 have you tried a 30 minute router reboot this often improves things?
Your post has been flagged for assistance and you should hear soon but please remember that the staff here work office hours.
