on 03-05-2021 03:20 PM
I renewed my contract a while back in about october, and at the same time i had an openreach engineer come out and check my connection, to find that from my home the cabinet, there was one of the two wires disconnected.
This resolved the half speed issue i was having for a bout a 6 months to a year.
This seems to have happened again. Cat5 connected direcly to router, i get only 50Mbps, even though im paying for the higher speed connection, and really need it for my work. The connection is solid, but its lost almost half the connection speed.
I have tried all the usual - used router provided, switched back to my Draytek V130, but yet the speed is not far off of half. Even left the router pluged out over night...
I'm in a new build set of flats and i can see the cabinet from window, less that 100 meters away.
Can this be fixed again somehow?
Cheers,
Wes
on 24-05-2021 08:28 AM
Thanks for the update. How has the connection/speed been over the weekend?
Thanks )
on 21-05-2021 08:04 PM
I just rebooted the router again and its back to 73MBps solid with good ping to 8.8.8.8...
Fixed itself it would seem.
on 21-05-2021 07:34 PM
An engineer came over, reset the connection from elsewhere, and the service went back up to 73Mbps. However, my connection, since this afternoon is experiencing alot of packet loss.
A ping to 8.8.8.8 times out ever 5-8 attempts to ping google's dns.
Is there an issue with the service for some reason? I have ran the line test etc, all checks out ok.
Can you help?
on 14-05-2021 09:43 AM
Hi breakz187_2,
I've replied to your PM
on 13-05-2021 10:51 AM
Hi breakz187_2,
Thanks for answering the security questions, I've sent you a PM requesting a little more information
on 13-05-2021 07:58 AM
Hi breakz187_2,
If you'd like us to arrange the engineer visit can you confirm:
on 12-05-2021 04:23 PM
Yes please.
Can you cancel the BrightSparks thing - the interactive webpage chat arranged that - sound like a waste of time. I think OpenReach would be best set to fix this.
on 12-05-2021 02:59 PM
Hi breakz187_2,
To investigate further we'll need to arrange an engineer visit. If you'd like us to do this please let us know and we'll confirm some details
on 12-05-2021 02:27 PM
New firmware - same connection speed
on 12-05-2021 01:34 PM
Device Info
Cable Modem Serial Number | N7183474N008009 |
Hardware Version | FAST5364 3.00 |
Software Version | SG4K10001400t |
GUI Version | 1.152.6 |
System Up Time | 00h34m27s |
Cable Modem MAC Address | D0:6E:DE:41:79:A7 |
Network
Local IPv4 Address | 192.168.1.1 |
Local Subnet Mask | 255.255.255.0 |
Local Ethernet Mac address | D0:6E:DE:41:79:AD |
Public IPv4 Address | 78.146.181.191 |
Public Subnet Mask | 255.255.240.0 |
Default Gateway | 78.146.176.1 |
Primary DNS Server | 79.79.79.79 |
Secondary DNS Server | 79.79.79.80 |
Wi-Fi
2.4 GHz Wi-Fi SSID | TALKTALK4179AD |
Status | Enabled |
Uptime | 00h33m58s |
MAC address | D0:6E:DE:41:79:AA |
Mode | 802.11 b,g,n |
Security | WPA2 Personal |
5.0 GHz Wi-Fi SSID | TALKTALK4179AD |
Status | Enabled |
MAC address | D0:6E:DE:41:79:AB |
Mode | 802.11 a,n,ac |
xDSL
Status | UP |
Connection Time | 00h33m20s |
Link Status | UP |
Standard | VDSL2 (G_993_2_ANNEX_ B) |
Line Encoding | DMT |
Link encapsulation | ATM (G_992_3_ANNEX_ K_ATM) |
Downstream | Upstream | |
Actual Rate [Kbps] | 49000 | 19999 |
Maximum Rate [Kbps] | 73221 | 19999 |
Noise Margin [dB] | 0.00 | 6.00 |
Attenuation [dB] | 16.70 | 0.00 |
Power [dBm] | 14.00 | 6.90 |
on 12-05-2021 01:33 PM
Its connected to the test socket with a laptop plugged straight in to the router, via a filter of course.
I have done numerous speed tests and it seem to be getting slower. 46/43
Router says its connected at 49.
I have tried another router, filter, cable etc. Also bought a cheap phone to test the dial tone, which sounds perfect.
Using the sagem FAST5364 3.00
on 04-05-2021 12:28 PM
Hi breakz187,
I've run a test on the line now which hasn't detected a fault, however I can see that the sync speed has dropped. Just to confirm, is the router currently connected at the test socket? Is the voice service ok with no noise on the line?
on 03-05-2021 05:40 PM
Hi @breakz187 have you seen tried the service centre in my account?
Your post has been flagged for assistance and you should hear soon but please remember that the staff here work office hours. It could take a while to work through the backlog
