Speed dropped from 150 to 3 meg overnight - wired connection
Moocow23
Message 4 of 4
Not sure what has happened but my G.Fast connection has dropped by x50 overnight.
Was online until about 1AM anyway and didn't notice a speed change, but this morning it is now topping out at 3MB/s on both wired and wireless speeds - currently using my 4G backup.
Have switched out my own router to the TalkTalk provided one but it is still the same.
Rebooted the Openreach modem a number of times - still the same.
I note that several people posted same after some "work" done last night so wondering if there is a wider issue that is NOT being reported on the status dashboard
3 REPLIES 3
Message 1 of 4
Noticed that status update now, only took you half a day to notice that your service is degraded across the country.
Message 2 of 4
I'm sorry for the delay. There is currently an incident raised which our team are currently investigating and I will post back here as soon as I receive an update back. It's for loss of service, however it's possible that this may also be affecting the speed.
Moocow23
Message 3 of 4
Now dropped to half a meg since I last checked at 10AM.
Upload speed is still within normal margins of 20-30 meg.
