on 13-06-2022 03:26 AM
Since last night the speed of my connection keeps dropping, then recovering. This happens almost every 30 seconds, if that, and is quite frustrating. The drop is instant, not gradual. I've attached a couple of screenshots of my speedtests and if you look at the progress bars, you can easily see the massive drops.
I have tried the troubleshooting to no avail.
Can anyone help? Any ideas what the problem is?
on 14-06-2022 08:39 AM
Hi scottieb
on 14-06-2022 08:34 AM
it seems to have stabilised since yesterday evening, and don’t seem to be having and drops in speed, very strange.
I will continue to monitor and if it returns will reply again to this thread.
thanks
on 14-06-2022 06:48 AM
If the connection is unstable with 2 different routers, cables and microfilters directly at the test socket and connected wired with no other equipment connected to the line, and the connection is also unstable on more than one device, then the next step would be to arrange an engineer visit to the property. If you would like to go ahead with this then please let us know and we can confirm some details with you.
on 13-06-2022 02:49 PM
No, the test was done with only one device connected, wired.
thanks
on 13-06-2022 02:47 PM
Hi scottieb
Are any other devices in use and connected at the same time? Is anyone uploading at the same time?
on 13-06-2022 02:40 PM
Hi, yes the stats look good when the speed is normal, but there is an intermittent problem with the speed plummeting, causing problems, mainly when playing games. You can see all the drops on the screenshots.
Both routers are talktalk, but different models, one Fast5364 and one DG8041W. I have a pre filtered master socket, so no filters needed but did change the cable. I also tested using the test socket inside the master socket and makes no difference to the results.
Nothing internally has changed in my setup, no new devices, nothing that can cause interference.
thanks
on 13-06-2022 01:27 PM
Hi scottieb
I have checked the connection stats again and the sync speed is just over 40mb.
There are 2 re connections showing on the line over the last 24hrs. The line test is clear, no faults detected.
Was the 2nd router you tested with a TalkTalk router? Did you also change the cables and filter?
Is the router located near to any devices that could cause any interference? (cordless handset etc)
on 13-06-2022 01:17 PM
Hi, I have already reconnected the original router.
The issue was exactly the same, with both. There was only one device connected when testing the speed. If you run a speedtest you will see the drop. Sometimes you will have to run one after the other as it doesn't show in every text, but almost guaranteed for the speed to drop within 60 seconds.
The connection doesnt drop, I always have an internet connection. But the speed does drop, it plummets instantly, not gradually.
on 13-06-2022 01:00 PM
Can I just confirm, with the alternative router currently connected, is the connection dropping, the speed slow or both?
on 13-06-2022 12:51 PM
Hi, yes I've just plugged it in, and only one wired device connected. The problem still occurs.
on 13-06-2022 12:31 PM
Ok thanks for confirming. Do you have a different router that you can test with just to rule this out please?
on 13-06-2022 12:19 PM
No lights change on the router. The original screenshots were performed on a WIFI device. Ive just done some more speedchecks, on a seperate device, these are all wired and will attach here. The issue is still here, on both WIFI and wireless.
There is definitely an issue. It may be intermittent, but something is not right. Online games are unplayable at the moment.
on 13-06-2022 11:58 AM
I've re-checked the connection stats and the connection looks stable so far today. Can I just confirm, are you connected wired or wireless? Do any of the lights change on the router when the connection drops please?
on 13-06-2022 11:45 AM
It is still the same as last night, but doesn't seem as frequent at it was, but at least every 60 seconds.
The 2 disconnects may have been me last night when I was troubleshooting. Even tho the drop in speed is rapid, there is no actual disconnect and i'm always connected.
Any ideas?
on 13-06-2022 08:16 AM
I'm sorry to hear this. I've run a test on the line now which is clear, however I can see 2 re-connections on the line. Can I just confirm, how is the stability at the moment please?
