Speed to my router = Poor
GLafford
Message 4 of 4
Ran a speed test on your site and I've only been getting at max 32mb download to the router.
  • I've reset the router - same
  • This is using a wired connection but same speeds on WiFi.
  • I've turned off and disconnected the router for 30mins+ today and same.
  • Tried new micro-filter - same
  • My speed status shows as POOR (see attached image)
  • I get occasional internet drops but not often or for any length of time.
  • Website and connection is okay just that I've been paying for a lot higher rated fibre speed for some time and not been getting it.
Router = Huawei HG633
Can you please test the line for me and get back with some actions and possible solution.
3 REPLIES 3
Message 1 of 4
Line tests are clear, so no issues evident when testing.
Check the home phone has a clear dial tone, no noise or crackles etc.
Would you like me to send a router for testing, to rule out any hardware issue ?
Message 2 of 4
Hi Debbie,
I have only every got at max between 28-32Mb speeds ranked as poor via your test previously.
I have made sure to close any applications that may use data download before running any tests.
GLafford
Message 3 of 4
Hi GLafford
I've completed a line test which hasn't detected any faults and your line is in sync at 36.5mb.
What speed were you previously receiving?
