Speed
carinf88
Message 14 of 14
I've had my broadband with you for 2 weeks now and my broadband speed is terrible! Even having one device connected like my PS4 I can't play online games. Keeps crashing and kicking me out. If I knew the speed was this bad I would of went somewhere else!
CFinlayson
13 REPLIES 13
Message 1 of 14
Router and returns bag are on the way.
carinf88
Message 2 of 14
Hi Michelle.
That's okay. Yeah might as well send another router to see if that will fix the problem. Fingers crossed.
Carin
CFinlayson
Message 3 of 14
Hi Carin,
I'm sorry for the delay. Would you like us to send a replacement router for testing purposes to rule this out? We would also send a router returns bag so that one of the routers can be returned.
carinf88
Message 4 of 14
Also I do remember the engineer having trouble getting a connection from the master socket.
Carin
CFinlayson
carinf88
Message 5 of 14
Also don't have another router. I never had this problem with previous broadband providers.
Carin
CFinlayson
carinf88
Message 6 of 14
I've tried it with a filter and wouldn't connect and tried another socket but again it just won't connect to the Internet.
Carin
CFinlayson
Message 7 of 14
All tests are clear but the sync speed of the router is very low.
Can you connect the router only to the master socket or 'Test Socket' if you have one , with a filter and see if the sync speed improves.
Also, have you tested another router to make sure the current router is not at fault ?
carinf88
Message 8 of 14
That's my home number added.
Carin
CFinlayson
Message 9 of 14
  • TalkTalk Telephone number
carinf88
Message 10 of 14
Hi there Michelle. Unfortunately my broadband speed is still incredibly slow. I've updated my profile like you said.
Carin
CFinlayson
Message 11 of 14
  • Name
  • Telephone number
  • Alternative contact number
Message 12 of 14
I have yes.
CFinlayson
Message 13 of 14
Have you worked your way through the help article?
https://community.talktalk.co.uk/t5/Articles/Fix-slow-broadband-speeds/ta-p/2204649
