Speeds have dropped by quite a way. Help please
jimmymumu
Whizz Kid
Message 126 of 126
Woke up the morning of the 14th to find my sppeds were running around 6mbps , way down from 55mbps. All day long it's been hovering anywhere between 4mbps up to 26mbps. Had to restart the router and it came back briefly but then dropped off again. I'm connected direct to socket via cable on a desktop pc running windows 7. Wireless started dropping off and on, on my tablet and phone too last night and thought nothing of it and i don't know if it's part of the same problem
125 REPLIES 125
Message 1 of 126
Hi jimmymumu
That's great news, thanks for keeping us updated 🙂
Message 2 of 126
Well this is the longest i've had a good service. Thank you and just hope it continues this way
Message 3 of 126
Hi jimmymumu
Thank you, please let us know how you get on.
Message 4 of 126
Thank you. I'll keep you updated
Message 5 of 126
It has been turned off again now.
Message 6 of 126
Brilliant. I'll let him turn it of and then see how that goes. If there is still trouble I will contact you for help. Much appreciated
Message 7 of 126
I will ask Karl to do this for you. Then let me know if you want my help.
Message 8 of 126
Would it not be possible to turn the setting off. He never said it was permanent. Thanks
Message 9 of 126
Hi @jimmymumu
@Debbie-TalkTalk has asked me to help you with your wireless problems.
The monitoring facility that @Karl-TalkTalk  has enabled will change any of the Wi-Fi parameters within the router that you may set. However, there are some bugs currently in the hub's firmware V2600, that prevent it being as effective as it should. Personally I don't like it being enabled currently until these bugs are fixed.
I can help a lot finding the best wifi channels & settings if you want, but don't be surprised if they are overwritten in the hub by this optimisation process is enabled. Please let me know if you want my help on this.
Message 10 of 126
Ok will do.
Message 11 of 126
Hi jimmymumu
If you could test a few different wireless channel just to see how the connection compares?
@KeithFrench provides really good advice on improving wireless performance. Could you help please Keith?
Message 12 of 126
I believe it was set to change automatically if it encountered a problem.. I can still do this if you want me to
Message 13 of 126
Hi jimmymumu
Could you try changing the wireless channel to see how the connection compares? Change your wireless channel
Message 14 of 126
All wired devices are fine and the light stays white and doesn't change. It may well be the router automatically changing the channel but not sure. It has happened twice today.
Message 15 of 126
Hi jimmymumu,
Could I just confirm, are wired devices ok? Does it happen on all wireless devices? How often is the connection dropping out? Do any of the lights change on the router when this happens?
Message 16 of 126
Hi. My wifi keeps dropping but Internet doesn't though. Could you check it out please
Message 17 of 126
Message 18 of 126
Will keep you updated thanks
Message 19 of 126
Yes, this will only affect any devices using wifi.  So if any congestion is detected on a specific channel, this will make a change to a better channel etc.
This is ON now. Any increase in wifi issues, let me know and we can turn this off.
The system will try to learn what devices are connected and note their connection characteristics to try to improve the wifi connection performance.
Message 20 of 126
Feel free to switch it on but my main connection is wired to my router so the interference on wifi should only affect my devices connected via wifi yes
