Speeds have dropped by quite a way. Help please
jimmymumu
Whizz Kid
Message 126 of 126
Woke up the morning of the 14th to find my sppeds were running around 6mbps , way down from 55mbps. All day long it's been hovering anywhere between 4mbps up to 26mbps. Had to restart the router and it came back briefly but then dropped off again. I'm connected direct to socket via cable on a desktop pc running windows 7. Wireless started dropping off and on, on my tablet and phone too last night and thought nothing of it and i don't know if it's part of the same problem
125 REPLIES 125
Message 21 of 126
Looking at the data for the last 3 days, the physical connection looks fine, speed and latency at the router are good, no external issues identified.
I am however picking up interference issues on both wifi broadcasts at times.
With this monitoring tool, we can turn on optimisation so the tool will automatically switch wifi channels if interference is detected and also band switching for devices that can utilise both 2Ghz and 5Ghz wifi.
This will auto switch between the 2 bands when range issues are detected.  Useful when moving around with a phone or tablet etc.
Do you want me to enable this feature to see if it is of benefit.  If not we can turn it off again.
Message 22 of 126
The router is up and running since Monday. Connection has been solid around 37mbps. Even when my son was on his xbox speeds only slightly dropped. Just hope it can stay like this now!!
Message 23 of 126
Bump the thread Wednesday morning and we'll take a look.
Message 24 of 126
okie dokie
Message 25 of 126
Just pushed the later firmware to the router.  Now lets give it a couple of days to gather some data and see if it shows anything.
Message 26 of 126
The WiFi hub is up and running. Thanks
Message 27 of 126
Cool, router could possibly arrive tomorrow.
Message 28 of 126
Okay will do. thanks
Message 29 of 126
No Problem 🙂
Let us know as soon as the router arrives and is connected and we can check the firmware is up to date so this will work with our monitoring tool.
Message 30 of 126
Ok sounds like a good idea. Thanks for the quick reply btw
Message 31 of 126
With this being a strange issue to diagnose I want to get a wifi hub out to you.  With this, we can use a network tool to actively monitor and record connection data that may help identify the issue.
Message 32 of 126
Sorry for the really late reply but got called away for a few days unexpectedly. Yesterday my other router was still only giving me between 2 and 11mbps unless i reset it, it would be fine for an hour then gradually drop. Remembered what you said about resetting the D-link so i used that. Even though i reset it, I've still been disconnected 6 times since yesterday. To me it seems too much of a coincidence that one router can't maintain the connection speed and the other constantly disconnects.
Message 33 of 126
Message 34 of 126
Yes of course. It will have to be a little later today as I'm about to go out. Thanks for your help btw
Message 35 of 126
Hi jimmymumu,
Ok thanks for letting me know. Would it be possible to factory reset the 3782 router and retest the stability again before we pass this over to our Network Team to find out what the next step will be?
Message 36 of 126
Yes it is and that is exactly the problem. If i don't reboot the router , the speed will just get slower and slower. If i do reboot it, sometimes it will be full speed for days and sometimes just hours.
Message 37 of 126
Hi jimmymumu,
Thanks for the confirmation. The line test is still clear, is the connection now stable with the HG633 but you're still having the reboot the router when the throughput speeds drop?
Message 38 of 126
Yes a cable straight from the router to my pc
Message 39 of 126
Hi jimmymumu,
Just to confirm, your PC is connected to your router by direct Ethernet cable not powerline adapters (home plugs)?
Chris-TalkTalk
Message 40 of 126
Hi jimmymumu,
We're experiencing a system issue at the moment so I'll pick this up later and get back to you
