Speeds have dropped by quite a way. Help please
jimmymumu
Whizz Kid
Message 126 of 126
Woke up the morning of the 14th to find my sppeds were running around 6mbps , way down from 55mbps. All day long it's been hovering anywhere between 4mbps up to 26mbps. Had to restart the router and it came back briefly but then dropped off again. I'm connected direct to socket via cable on a desktop pc running windows 7. Wireless started dropping off and on, on my tablet and phone too last night and thought nothing of it and i don't know if it's part of the same problem
125 REPLIES 125
Message 61 of 126
My sync speed may be showing that but my actual speed is totally different. At the mo it is 13.7 download and 8.2 upload using your online speed test. I know if i reboot my router it will increase my speed to 54 but why should i need to be doing that so often, that's not normal is it?
Message 62 of 126
Hi jimmymumu,
Your current sync speed is 57.6Mbps, how has it been since your last post?
Message 63 of 126
My speeds were fine for nearly a full week but i find it's gone back to how it was. I only get full speed if i restart my router or hard reset it. At first that would last 2 days but now, I'm having to reset it almost every day. Getting really tired of this now. Nothing has changed from my first post on this thread to now.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Korps>ping google.co.uk
Pinging google.co.uk [216.58.213.3] with 32 bytes of data:
Reply from 216.58.213.3: bytes=32 time=13ms TTL=55
Reply from 216.58.213.3: bytes=32 time=16ms TTL=55
Ping statistics for 216.58.213.3:
Minimum = 13ms, Maximum = 16ms, Average = 13ms
C:\Users\Korps>tracert google.co.uk
Tracing route to google.co.uk [216.58.213.3]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 * * * Request timed out.
3 8 ms 11 ms 8 ms host-78-151-229-241.as13285.net [78.151.229.241]
4 8 ms * * host-78-151-229-240.as13285.net [78.151.229.240]
5 13 ms 13 ms 13 ms host-78-144-11-37.as13285.net [78.144.11.37]
6 16 ms 13 ms 15 ms host-78-144-4-35.as13285.net [78.144.4.35]
7 13 ms 13 ms 13 ms 108.170.246.129
8 14 ms 16 ms 14 ms 172.253.65.209
9 18 ms 13 ms 16 ms ber01s14-in-f3.1e100.net [216.58.213.3]
Trace complete.
C:\Users\Korps>
Message 64 of 126
Message 65 of 126
Of course and thanks for your help.
Message 66 of 126
Hi jimmymumu
Please can you continue to monitor the connection and let us know if you do experience any further issues.
Message 67 of 126
Hi, we had a drop on Saturday which was cured by restarting the router. It had dropped to around 18mb. Since then it is as it should be. Thanks.
Message 68 of 126
Hi jimmymumu
How have you found the connection over the weekend?
Message 69 of 126
Hi jimmymumu
If you still experience this fault following the factory reset then please post back on this thread and I will let our Network Team know.
Message 70 of 126
Whilst I'm happy there are no obvious issues, it does rather concern me that the problem still continues unresolved. I'm more than happy to do as you've asked. What happens if the problem persists with no solution?
Message 71 of 126
Hi jimmymumu
Our Network Team have advised that all the line tests are passing with no issues. They also advised that the only thing they could see was that the service was down from the late hours on the 13th through to 5am on the 14th. Other than that, nothing to state any issues at all. The Ping and traceroutes you sent over are also fine so nothing to worry about there.
They have asked if you can do a factory reset and retest this evening?
Message 72 of 126
Thank you
Message 73 of 126
Hi jimmymumu
I have asked our Network Team to take a look at this and I will post back on this thread as soon as I receive further information.
Message 74 of 126
It's still running slow so I've just done them again. here's the reslts
Pinging google.co.uk [216.58.211.163] with 32 bytes of data:
Reply from 216.58.211.163: bytes=32 time=14ms TTL=54
Reply from 216.58.211.163: bytes=32 time=18ms TTL=54
Ping statistics for 216.58.211.163:
Minimum = 14ms, Maximum = 18ms, Average = 15ms
Tracing route to google.co.uk [216.58.211.163]
3 11 ms 8 ms 10 ms host-78-151-229-241.as13285.net [78.151.229.241]
4 * 8 ms 9 ms host-78-151-229-240.as13285.net [78.151.229.240]
5 20 ms 13 ms 13 ms host-78-144-11-37.as13285.net [78.144.11.37]
6 13 ms 13 ms 15 ms host-78-144-4-35.as13285.net [78.144.4.35]
7 14 ms * 18 ms 74.125.242.65
8 14 ms 16 ms 14 ms 172.253.50.223
9 14 ms 13 ms 17 ms lhr48s13-in-f3.1e100.net [216.58.211.163]
Trace complete.
C:\Users\Korps>
Message 75 of 126
Thanks for running the tests, did you run the ping and traceroute when the speed had dropped to 13Mbps?
Message 76 of 126
Did several speed tests via the tool, all day yesterday 55mb. Then last night back down to 13mb even though nothing had changed.
Ping results etc
Pinging google.co.uk [216.58.210.227] with 32 bytes of data:
Reply from 216.58.210.227: bytes=32 time=14ms TTL=54
Ping statistics for 216.58.210.227:
    Minimum = 14ms, Maximum = 14ms, Average = 14ms
Tracing route to google.co.uk [216.58.210.227]
  3    11 ms     9 ms     8 ms  host-78-151-229-241.as13285.net [78.151.229.241]
  4     8 ms     8 ms    11 ms  host-78-151-229-236.as13285.net [78.151.229.236]
  5    23 ms    19 ms    14 ms  host-78-144-11-187.as13285.net [78.144.11.187]
  6    17 ms     *       13 ms  74.125.51.108
  7     *        *        *     Request timed out.
  8    14 ms    14 ms    14 ms  172.253.68.216
  9    14 ms    17 ms    14 ms  172.253.68.213
 10    14 ms    17 ms    14 ms  lhr48s12-in-f3.1e100.net [216.58.210.227]
Trace complete.
C:\Users\Korps>
Message 77 of 126
Message 78 of 126
Yes of course i can. I have been using that speed test and log in to match the results to my account.
Message 79 of 126
Hi jimmymumu,
Can you run 3 speed tests at different times of day on the My Account speed checker on a device connected by Ethernet cable to your router (can you try to make sure that no other devices/applications accessing the internet at the time)
Can you also run a set of pings and a set of traceroutes to www.google.co.uk and can you post the results. Can you run the tests on a device connected by Ethernet cable to your router
https://help2.talktalk.co.uk/how-do-i-perform-ping-or-traceroute
Once we have this information we'll ask our network team to take a look
Message 80 of 126
And as predicted it's now dropped to between 2mb and 6mb. It was 55mb till around 4ish. Something clearly not right isn't there?
