Speeds
Bazzatay
Whizz Kid
Message 24 of 24
Hello
Houston we have a problem.
I had F35 for many years sync at 40mbs pulled in a download of 38 constant.
Upgraded to F65 and I come in from work and see In from work testIn from work testRouter rebootRouter reboot45min shut down45min shut down
23 REPLIES 23
Message 1 of 24
Thanks for the update and please let us know how the connection compares 🙂
Message 2 of 24
New router arrived yesterday and I connected it up this afternoon will monitor it over the next week or so, thank you for the swift delivery.
Message 3 of 24
Hi Debbie
Thanks, I shall post back here when the new router has been connected.
Message 4 of 24
Hi Bazzatay
Message 5 of 24
Hi Debbie
Yes please that would be good thanks.
Message 6 of 24
Hi Bazzatay
Would you like me to send a different router for testing?
Message 7 of 24
Hi Michelle
Yes it seems to be the case, the dowload speed drops after a few days and a reboot brings it back to where it should be.
No I don't have another router to test with I've had this HG633 for a number of years now and never had a problem with it until the upgrade to Fiber65..
Message 8 of 24
Does the speed eventually drop again until you have to reboot the router again? Do you have an alternative router that you can test with?
Message 9 of 24
Hi Michelle thanks for the reply.
Yes this is the predicted.
You can look forward to an estimated download speed between 35.0Mbps and 54.1Mbps with a minimum guaranteed speed of 28.5Mbps.
On fiber 35 my router was in sync at 40Mbps and I had a constant 37Mbps download speed.
Here is a speed test from tonight when I got in from work still at the test socket.
03-08-2103-08-21
Edit
After a router reboot.
Message 10 of 24
Thanks for confirming this. I can see that the sync speed has dropped slightly. Did you receive a predicted speed range prior to the upgrade?
Message 11 of 24
Hi Debbie thanks for the reply.
Yes it's still in the test socket.
This is a speed test from this evening
02-08-2102-08-21
Best Regards
Message 12 of 24
Hi Bazzatay
I've checked the connection stats and the line is now in sync at 42.9mb.
Did you connect the router at the test socket and power it down for 30 minutes?
Message 13 of 24
Hi Bazzatay
Sorry for the delay.
I've checked the connection stats and your line is showing in sync at 46.2mb.
Would it be possible to connect the router at the test socket, then power down the router for 30 minutes. After the 30 minute power down please can you keep the router switched on (without rebooting) over the weekend? We can then check the connection stats again on Monday to see if DLM has made any changes to the speed/profile.
Skynet_TX
Message 14 of 24
If you are getting very low throughput on wired as well as wireless then it might just be worth trying another extended power down. I've certainly seen other customers say that their initial +30 minute shutdown did not help, but a longer additional shutdown did resolve it.
I agree that anything +30 minutes should be enough, but if it was convenient to shut it down for a longer period of time then there is a chance that might help.
Message 15 of 24
@Skynet_TX wrote:
So which are you concerned about,
The fact that you are getting a sync of 44 and you expect more on Fibre 65
Or the fact that 44 is as expected but your throughput is much lower
or both ?
I think the 5mbps download is pretty much a givaway
Skynet_TX
Message 16 of 24
or both ?
Message 17 of 24
Yes, what did I miss?
Message 18 of 24
@ferguson wrote:
What speeds were you told to expect? Maybe that's as fast as it goes, it is certainly more than you would get on Fibre 35 which is capped at 40.
Did you read the post ????????????????????
Plank
Message 19 of 24
@Skynet_TX wrote:
Ah, I missed the little caption, I'm getting to old to see little text like that 😉
Me to lol
Message 20 of 24
Do you have any wired devices, if so do they also have such slow throughput ?
