Speeds
Bazzatay
Whizz Kid
Message 24 of 24
Hello
Houston we have a problem.
I had F35 for many years sync at 40mbs pulled in a download of 38 constant.
Upgraded to F65 and I come in from work and see In from work testIn from work testRouter rebootRouter reboot45min shut down45min shut down
23 REPLIES 23
Message 21 of 24
What speeds were you told to expect? Maybe that's as fast as it goes, it is certainly more than you would get on Fibre 35 which is capped at 40.
Message 22 of 24
It was a free deal buddy and yes if you look at the captions they tell you what they are
Skynet_TX
Message 23 of 24
Hi @Bazzatay,
Have you tried switching the router off for over 30 minutes to force it to create a new session when it is switched back on ?
Did TalkTalk tell you what your estimated speed would be on Fibre 65, as if your line can only handle 44 then it is barely worth upgrading and paying the extra !
